You can order a LCD panel from eBay. Use Powerstrip (software) to get the LCD panel model no. Also provide them with laptop model number, screen size and resolution. Replacing the LCD is very easy. New screen should cost approx. 10k if you are lucky.
I'd suggest to start using it as a desktop PC with external monitor. Spending that much money in old laptop is not worth it.
