Hi,
I have an old PC (P4 1.7, 845GL MB, 1GB RAM, 2 optical drives and 2 hard drives). The PC is about 4-5 years old, and I bought it assembled, so I really don't know the power supply wattage (i'm assuming 200-250 W) nor can I see any rating on the power supply without disassembling the PC.
While installing the second hard drive, I ran out of molex connectors and had to disconnect the case fan to connect it. While the PC seems to be running OK for the moment, I would like to re-attach the case fan. Would it be dangerous to attach a splitter to one of the existing molex connectors to run the case fan? If not, should I attach it to a optical drive connector or to a hard drive connector?
Vikram
