Old 17-10-2007, 12:29 AM   #1 (permalink)
sagar_coolx's Avatar
Default ddr2 667 runnin at 333mhz
dudes i have intel c2d e2140 on asus p5 gc mx with a 1gb transcend ddr2 667 mem module....now afair, my mobo supports ddr2@533...but everest shows the module is runnin at 333 mhz....is there any setting i need 2 enable to run my memory faster?
sagar_coolx is offline
Old 17-10-2007, 12:58 AM   #2 (permalink)
Alpha Geek Banned
bikdel's Avatar
Default Re: ddr2 667 runnin at 333mhz
nah... ur ram is running at 667 mhz no doubt... just because its DDR (double data rate) , the software is reducing the speed by half...
check for urself... 333x2=666 Mhz ~ 667 Mhz
got it dude?
I'm not a GEEk, i still use Windows!
bikdel is offline
Ddr/ddr2?? drcaesar Hardware Q&A 7 15-10-2007 03:26 PM
DDR 256MB>DDR 333Mhz+DDR 400Mhz means motherboard gone!!!? praka123 Hardware Q&A 12 03-09-2007 01:03 AM
Installin Linux wit Vista already runnin... deepakprabhakaran Open Source 1 19-08-2007 12:51 AM
DDR2 help codename_romeo Hardware Q&A 5 02-12-2006 10:40 PM
why r so many processes with same name runnin??? ssk_the_gr8 Software Q&A 4 05-03-2006 02:13 PM
- by kool
