Re: Problem during DVD burining process
I am using Nero OEM 6.6.1.6 version for DVD writing.
DVD writer was alongwith PC . I am unable to get driver provided by Compaq.
I uninstall and intalled DVD/CD ROM driver, again tried to burn DVD but fialed.
Error details are as follws:
Aloke
1A20-620E-0012-2525-1283-2378*
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 11/21/2005 11:18:20 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 7/12/2006 3:28:31 PM
NT-SPTI used
Nero Version: 6.6.1.6
Internal Version: 6, 6, 1, 6
(Nero Express)
Recorder: <HL-DT-ST DVDRRW GSA-H20L>Version: S742 - HA 1 TA 0 - 6.6.1.6
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVDRRW GSA-H20L >Version: S742 - HA 1 TA 0 - 6.6.1.6
=== Scsi-Device-Map ===
DiskPeripheral : ST3160812AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRRW GSA-H20L atapi Port 5 ID 0 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRRW GSA-H20L F: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 703MB (720172kB)
Free physical memory: 177MB (182260kB)
Memory in use : 74 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.10.2007
ISO compilation
7:21:07 PM #1 Text 0 File Isodoc.cpp, Line 6475
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
7:21:07 PM #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
7:21:07 PM #3 Text 0 File Reader.cpp, Line 124
Reader running
7:21:07 PM #4 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRRW GSA-H20L running
7:21:07 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
7:21:08 PM #6 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using DVD media
7:21:08 PM #7 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1968047 (437:20.47, 3843MB)
7:21:08 PM #8 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
7:21:08 PM #9 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: HL-DT-ST DVDRRW GSA-H20L, Media type: DVD-R
Disc Manufacturer: MBI 01 - RG40
Disc Application Code: 64, Disc Physical Code: 193
7:21:08 PM #10 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
7:21:08 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1968048 (1968048) = #1968048/437:20.48
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1968048 blocks [HL-DT-ST DVDRRW GSA-H20L]
7:21:08 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [HL-DT-ST DVDRRW GSA-H20L] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4030562304, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1968048 | lead-out | 1 | 0x41 | 0x00
7:21:08 PM #13 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
7:21:08 PM #14 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
7:21:08 PM #15 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
7:21:08 PM #16 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
7:21:08 PM #17 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
7:21:08 PM #18 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 16x (22,160 KB/s)
7:21:08 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:21:08 PM #20 Text 0 File DVDR.cpp, Line 2727
Recording mode: Sequential Recording Mode for Multisession
7:21:08 PM #21 Text 0 File DVDR.cpp, Line 2883
Start write address at LBA 0
DVD high compatibility mode: Yes
7:21:08 PM #22 Text 0 File Cdrdrv.cpp, Line 8648
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:23:17 PM #23 SPTI -1 File SCSIPassThrough.cpp, Line 289
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x80
Sense Qual: 0x04
CDB Data: 0x2A 00 00 03 D4 20 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 80 04
Buffer x06d70000: Len x10000
0x0D 95 EE 61 DC C3 62 F7 49 ED D5 0E CF BE ED 37
0x9D 7D DD B4 DC ED 37 CE 9F 76 4F 4F B5 B9 A6 9E
0xFB BA B4 EC 3A F6 C6 E6 D2 38 FB DA 1D B9 CF 13
7:23:17 PM #24 CDR -1 File Writer.cpp, Line 311
Unspecified Recorder Error
F: HL-DT-ST DVDRRW GSA-H20L
7:23:17 PM #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:23:17 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:23:17 PM #27 Text 0 File DVDR.cpp, Line 3123
EndDAO: Last written address was 250911
7:23:17 PM #28 Phase 133 File dlgbrnst.cpp, Line 1685
Writing short lead-out
7:28:40 PM #29 Phase 39 File dlgbrnst.cpp, Line 1685
Burn process aborted
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 7/27/2007 4:36:18 AM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 11/21/2005 11:18:20 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 7/27/2007 4:36:18 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Reason: Automerged Doublepost
