Old 14-10-2007, 01:12 PM   #1 (permalink)
Exclamation CPU Temp 103 C HELP!
I have an Intel Pentium 4 3.0GHZ CPU installed on a Intel 915GAV M/Board. My CPU was restarting and in latter days it was suddenly turning off. This I knew was due to overheating. The temp remained at 85C to 95C with LEAST LOAD. I began to suspect that if the assembler had applied thermal paste or not. So I opened the heatsink and found that there was thermanl paste, but very low in amount. I scrapped of everything and cleaned the two surface(cpu and hs) with acetone. But now I cannot find thermal paste and the computer runs for 3 secs now(due to overheating). So I bought a local CPU Cooler for just test puposses (Brand is "Sheen") and mounted it. I got a packet of thermal paste with it. The paste was White in colour form which I understood that it was Zinc Oxide based and doesnot cool as efficiently as micronised silver based t/pastes.The computer starts and temp remains at 72C with full load. Now where can I get(any shop and telephone no address please) thermal paste , rather Arctic Silver in Kolkata. I was unable to find it in two leading shops who keep almost any hardware.They see they donot know where it is availlable. Is it availlable in Chandni Chawk?
neel12345 is offline
Old 14-10-2007, 01:18 PM   #2 (permalink)
I<3C0FF$£
AquaWolf's Avatar
Default Re: CPU Temp 103 C HELP!
http://www.amazon.com/Arctic-Silver-.../dp/B000BSLU2S
This what your looking for?
I dare say these are my horrible specs
OS: WinXP Pro SP2 CPU: AMD Athlon XP 2500 (Barton) , 2.16 GHz Graphics: Radeon 9250 Sound: NVIDIA nForce HD: 189.91GB Total Physical Memory: 768 MB
AquaWolf is offline
Old 14-10-2007, 01:19 PM   #3 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^get arctic silver 5 or better MX2(not sure about the name).As5 will cosy you around 400.All leading computer hardware store stores them.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 14-10-2007, 01:34 PM   #4 (permalink)
assasin's Avatar
cudnt find AS5 in Kolkata.so got myself a pack of CoolerMaster thermal paste (HTK-002).cost me 425 all incl.
bought it from Classic Computers.
assasin is offline
Old 14-10-2007, 06:20 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
In the title you said 103 deg C !
You can make tea on your CPU
NucleusKore is offline
Old 19-10-2007, 12:49 AM   #6 (permalink)
I dont want to ruin my CPU,though I will shortly upgrade.still....
Old 19-10-2007, 01:18 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
1) check processor fan, SMPS fan and cabinet fan.All should run smoothly.
2) There must be lots of dust on processor fan.Clear those dust..but very carefully and very neatly.
ravi_9793 is offline
Old 19-10-2007, 07:58 PM   #8 (permalink)
jasku's Avatar
Yup, I jus cleared **** LOADS of dust today, and the idle temps came down from 75C to 43C!...and as for AS5, here is an indian retailer sellin it for 500
http://www.yantraonline.in/ProdDetails.asp?ItemCode=495
All the best! and let us know how it goes.
jasku is offline
Old 19-10-2007, 08:31 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
dust over processor is common cause of overheating.People generally ignore it.
Old 20-10-2007, 04:04 PM   #10 (permalink)
I clear the dust every month, and I cleared it just 8 days ago, so it shouldnot be a problem.
hdd temp xbonez Hardware Q&A 5 06-04-2007 02:01 PM
Any S/w That Displays Cpu Temp? return_of_vengeance Hardware Q&A 8 22-09-2006 06:50 PM
pc temp issues hunk_freak QnA (read only) 2 12-06-2006 12:05 PM
CPU Temp (55-60) is high ???? ASH_DSG Hardware Q&A 6 11-03-2006 09:09 PM
Processor Temp dorai QnA (read only) 3 13-11-2004 09:26 PM
- by kool
