Old 14-10-2007, 11:33 AM   #1 (permalink)
Default Ddr/ddr2??
im using MSIRS482M2-IL motherboard..does it support DDR2 RAM?? how do i find it out? theres nthng on the manufacturers site for this product?
thank u all in advance
drcaesar is offline
Old 14-10-2007, 01:20 PM   #2 (permalink)
I<3C0FF$£
AquaWolf's Avatar
Default Re: Ddr/ddr2??
MSI RS482m2-IL motherboard
Source: http://www.laptop-shop.co.uk/MSI-mem...ory-1-ram5.htm
I dare say these are my horrible specs
OS: WinXP Pro SP2 CPU: AMD Athlon XP 2500 (Barton) , 2.16 GHz Graphics: Radeon 9250 Sound: NVIDIA nForce HD: 189.91GB Total Physical Memory: 768 MB
AquaWolf is offline
Old 14-10-2007, 01:36 PM   #3 (permalink)
dOm1naTOr's Avatar
Nup, it support only DDR400 mhz in single or dual channel upto 4GB.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 14-10-2007, 02:21 PM   #4 (permalink)
THANKS!!! i have a 512 MB module..can i pair it with a 1 GB module(of the same freq)..or do i need to have both modules of the same capacity..
drcaesar is offline
Old 14-10-2007, 02:25 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ No need. For best compatibility, use RAM modules of same frequency and timings. Different sized RAM modules will work in single channel without probs.
If you wanna haf a Dual Channel setup then you'll need RAM of same frequency, timings and also capacity.
infra_red_dude is offline
Old 14-10-2007, 02:28 PM   #6 (permalink)
thanx !!
---------Alcohol doesn't solve any problems, but if you think again, neither does Milk.---------
drcaesar is offline
Old 15-10-2007, 12:19 AM   #7 (permalink)
Alpha Geek Banned
bikdel's Avatar
yeah but in most of the cases RAM modules of different timings can be made to work in dual channel by forcing the higher timing on both modules...
hell i use diff frequency modules in dual chhannel, and here its just timings we are talking about...
I'm not a GEEk, i still use Windows!
bikdel is offline
Old 15-10-2007, 03:26 PM   #8 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Ever thought why these companies give a Dual Channel modules for somewhat extra price compared to that of separated single modules?
keith_j_snyder2 is offline
DDR2 help codename_romeo Hardware Q&A 5 02-12-2006 10:40 PM
DDR & DDR2 Ram jatinkompelli QnA (read only) 10 12-06-2005 11:36 AM
Is DDR2 Ram In sachinc QnA (read only) 4 19-01-2005 08:54 PM
how to use 2 ddr to get ddr2???? mylifevp QnA (read only) 1 29-12-2004 09:59 PM
- by kool
