Old 13-10-2007, 07:00 PM   #1 (permalink)
the_player's Avatar
Default Critical problems ______ someone please Help
hi,
I decided to format only the C: Drive of my system.
WHAT HAPPENED
I have a very strange problem.
when I format my system & run the setup of Windows XP , after some time my computer freezes, one blue screen comes and one short message comes
The Stop Error code which comes is --> 0x000000A
This happens everytime during XP installation(with the same error code). When 9 minutes are remaining for the setup to complete, the above Blue Scrren of Death(BSOD) appears.
HISTORY
3 months ago, it so happened that my system was not booting.
So I removed my Floppy Disk Drive from my system.
My system booted up & started functioning.(ie my problem was solved)
ALTERNATIVE MEASURE TAKEN
Since the problem refused to give way, I decided to install another OS in my system. Therefore, I decided to install KUbuntu OS on my system.
But after the occurance of KUbuntu desktop on screen, when I run the install.exe of Kunbuntu, my system hangs randomly after that .
Once it so happened, that nothing showed on the monitor screen after the Power ON.
CONCLUSION
I suspect the following 3 components of my CPU
1. Pentium 4 1.9GHz CPU (_Its overheating______)(Probability : Low)
2. Mercury 300Watts Power Supply(_refer HISTORY written above)(Probability : High)
3. Corsair 512MB @ 400MHz DDR RAM(____because of the BSOD) (Probability: Medium)
SYSTEM SPECIFICATIONS
HIS motherboard P4M266A/8235 @ 533MHz FSB
Intel Pentium 4 @1.9GHz
512MB Corsair DDR memory @ 400MHz
XFX GeForceFX 5200 128MB graphics card with AGP 8X
DLink 56Kbps Modem(standard)
Mercury Power Supply 300Watts
Samsung 60GB hard disk
APC 500VA UPS
Someone please help, as I am confused thoroughly & am getting frustrated with this problem.
SOS
the_player is offline
Old 13-10-2007, 07:07 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Critical problems ______ someone please Help
Since you've narrowed down to the problems (I really appreciate that ), try eliminating it one by one. If you can get a stick of RAM and a PSU from a friend then test them out.
The GFX card may also be the culprit. Does your computer haf onboard video? If so then try installing the OS on that and adding the GFX card later. Remove all the PCI/AGP whatever etc. cards and try installing on a barebones system.
infra_red_dude is offline
Old 14-10-2007, 03:26 PM   #3 (permalink)
the_player's Avatar
Unhappy Re: Critical problems ______ someone please Help
Thanks for the suggestion infra_red
I am writing down my observations on this post, so that these can give you(& others reading this), more idea. These were written before this problem was posted, but due to some reason I wasn't able to write in in post, therefore writing now.
These observations have been written the moment errors occured on screen
LEGEND
ob# stands for the observations____ Words in double quotes are the messages/errors displayed by the system____Words without codes denote actions taken by me
ON - system is powered ON through the power button
OFF - system is powered OFF through the power button
OBSERVATIONS
ob#1
ON
After the boot,
"Verifying DMI Pool Data",
then
"Remove disks or other media
Press any key to restart "
After pressing a key
"Disk boot failure Insert Boot Disk when ready"
OFF
ob#2
ON
Win XP Boot disk inserted, disk detected & XP setup began
System hanged at the XP initialisation screen, i.e. at the blue screen of XP set up when it begins to load drivers like ATAPI, IDE, etc.
OFF
ob#3
Removed modem from the CPU cabinet
ON
"Updating ESCD..............Sucess"
It asked for boot disk, inserted the KUbuntu OS CD
"Uncompressing Linux...................."
"crc error"
and the system became responseless
OFF
ob#4
Inserted modem in its proper place(PCI slot)
ON
RAM is not detected
OFF
ob#5
same as ob#4
ob#6(This scene appeared thrice at 3 different installations of KUbuntu)
ON
KUbuntu setup
KUbuntu desktop(setup not )
Hanged when clicked on "Install" of KUbuntu desktop
OFF
ob#7
ON
Error at the MainBoard screen
"Primary IDE channel no 80 conductor cable installed
Floppy disk(s) fail(40)
CMOS checksum error - default loaded
Press F1 to continue "
After pressing F1
"Remove other disks or media
OFF
ob#8
Removed & reinserted the power & data cable of Hard Disk
ON
Output same as observation #7
OFF
Removed both the power & data cable of Hard Disk
System started without Hard Disk
ON
same as ob#7
OFF
All observations over
Someone, please help me.
Old 14-10-2007, 05:54 PM   #4 (permalink)
club_pranay's Avatar
i must appriciate the technical edge to your question and observation.
i had a similar problem on my system once.
  1. Try installing Xp with only one HDD installed: loosly fit power cables, IDE/SATA connectors, misbehaving IDE/SATA Ports can contribute to the problem. Using only one HDD can realy drop the chances of error.
  2. Try installing Xp on other HDD: When my Sata-Seagate crashed, my system would go slow, sometimes it would freeze with a ugly bsod.
  3. U seem technicaly sound so cross check everything before drawing a conclusion. things like RAM slots, ram sticks are very critical. and try to strip down your system to a bare minimum spec.
i used to get realy realy fustrated with these type of problems, so keep your cool! best of luck!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 14-10-2007, 06:10 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
it seems that u have a lot of addon cards on ur machine .... remove all of them use onboard as suggested and install if the problem still occurs change ram and see if the problem still occurs it means that something other than the ram is the culprit so now change hdd and see (which i dont think shud b causing the problem)
http://beingmanan.com
iMav is offline
Old 14-10-2007, 07:20 PM   #6 (permalink)
Wire muncher!
Originally Posted by the_player
OBSERVATIONS
ob#1
ON
After the boot,
then
OFF
Error is due to the fact that the system is unable to find any bootable media.
ob#2
ON
OFF
Check the IDE/Power connectors on the HDD as well as on the mobo.
ob#3
ON
"crc error"
OFF
The Kubuntu CD most prolly has gone bad and hence the CRC error.
ob#4
ON
RAM is not detected
OFF
Mostly due to loose connection.
ob#5
same as ob#4
ON
KUbuntu setup
OFF
Looks like a problem with hard disk.
ob#7
ON
After pressing F1
OFF
You are using an old 40pin 40 conductor IDE cable. Get a new one which is a 40pin 80 conductor cable to get good transfer speed and performance (greater than UATA/33)
The floppy drive (if not gone bad) had the cable connected in the reverse way. Check it out.
CMOS error mostly means a drained CMOS battery. Replace that. Or check that the BIOS clear jumper is not set to clear the BIOS setting at every boot. Refer to the mobo manual.
ob#8
ON
OFF
ON
same as ob#7
OFF
Check your hard disk for bad sectors. It mostly appears to be a problem with the hard disk.
Old 15-10-2007, 06:54 PM   #7 (permalink)
the_player's Avatar
Exclamation Re: Critical problems ______ someone please Help
Thank You : infra_red, clup_pranay & iMax
Today I have performed some more experiments & have noted down below mentioned observations
LEGEND
DAY 4
ob#1
Replaced my XFX GeForce FX 5200 128MB AGP 8X with nVidia GeForce 2/MX 400 64MB AGP
ON
"Primary IDE channel no 80 conductor cable installed"
"Floppy Disks fail(40)"
"Press F1 to continue"
After pressing F1
Press any key to restart"
OFF
Conclusion#1 My Graphic card is NOT the culprit
ob#2
Removed the modem
ON
Inserted XP bootable CD when it asked for "Insert boot disk"
BSOD arose
The error it flashed :
"BAD_SYSTEM_CONFIG_INFO
STOP : 0x00000074
OFF
ob#3
Put the modem back to its PCI slot
Win XP CD inserted as a boot device
System restarted unexpectedly at the XP initialisation screen, i.e. at the blue screen of XP set up when it begins to load drivers like ATAPI, IDE, etc.
After the restart same steps as above, this time system hanged at the XP setup initialization screen
OFF
ob#4
Replaced my Corsair 521MB DDR400 RAM with Hynix 256MB DDR(Grahpic card is GeForce2 MX 400 64MB & not XFX)
ON
"Primary master : none
Primary Slave : none
Secondary master : Samsumg CD-RW
Secondary slave : none "
Still continued with the XP setup screen
"Setup did not detect any secondary storage connected to the system ___F3 to quit"
F3
OFF
NOTE: ob#4 (i.e. Hard Disk not detected occured thrice, after reconnecting the connectors)
ob#5
ON
"Primary master : SAmsung 60GB Hard Disk
OFF
All observations of the day are over
CONCLUSIONS
Since both the RAM & Graphics card after replacement don't behave differently, I think Hard Disk or my SMPS(PSU) are the problem causers
Also KUbuntu CD is working fine now
I suspect my Power supply, as its 4 years old now as against my Hard Disk which is 2 years old
Please help as I don't have extra Power supply & Hard Disk to perform any more experiments
SOS as I am confused
Old 15-10-2007, 09:37 PM   #8 (permalink)
Well you've tried almost everything......try swapping the hdd and cdrw cables.
Take out the hdd from it's bay and when you switch on the system,place your hand on the hdd lightly to feel for some vibrations etc which should signify whether or not the hdd is coming on.There should also be a light 'tick' sound when the hdd comes on.
I think it's a case of a loose hdd power supply connector......try a different connector.
And work with only the Hynix ram.
Good luck.
sashijoseph is offline
Old 16-10-2007, 03:15 PM   #9 (permalink)
refer to my post below
http://www.thinkdigit.com/forum/show...4&postcount=10
realdan is offline
Old 16-10-2007, 05:00 PM   #10 (permalink)
it's not the confusion of a ram type my friend "realdan".
anyways, as suggested by joseph, seems a problem in the IDE area(IDE ports, cables or even the drives)
u can try this conf too.
make the CDROM, your primary master, HDD your primary slave(check with the jumper settings). i mean on one cable only
if it doesnt work, change the IDE and POWER cables.
if it doesnt work, change the setup to secondary settings.
pls tell if this works or not.
Old 16-10-2007, 10:02 PM   #11 (permalink)
assasin's Avatar
borrow a psu from ur frnd and try.
i think ur hdd is the root of the prob.backup all ur data and do a full zero fill.this sud solve the prob.
assasin is offline
Old 17-10-2007, 05:47 PM   #12 (permalink)
the_player's Avatar
Guys,
Thank You very much ________ especially infrared_dude.
WHAT I DID
Installed the same 256MB DDR Hynix RAM
Installed nVidia GeForce 2 MX 400 64MB AGP card
I purchased a new Data cable(the cable which runs from MotherBoard to HDD) & fit it in my cabinet________ & ______ bingo, the drive was recognised.
Plus all the contents in my other drive were undisturbed.
This problem of mine led me to purchase another 160GB Seagate Barracuda 7200rpm IDE drive :-/ which cost me around Rs. 2225/-
I also had another problem_____ my pen drive was not recognized _____ now even this problem of mine is solved(Honestly I don't know how it got solved)
ITS NOT OVER YET
I am going to test my system for BSODs & sudden restarts. If everything works fine, then I will restore my XFX GeForce FX & Corsair 512MB RAM
On Sunday I will restore my graphics card & RAM ______ & will let all of you know through this post_____ till then, no games for the_player ((
Once again, Thank You everyone.
Old 17-10-2007, 09:33 PM   #13 (permalink)
good job!! congrats!!
believe or not.. i had this strange system hanging problem.. the cause was power shortage!! ...i had too many things inside my cabinet. When i upgraded to a 500w smps, everything was up n running! even the thermometer, which never worked, started giving readings!! And the old 300W smps is happy in my older machine.
ialmnt5.sys critical error! please help fast!!!!! thetopcyborg Software Q&A 3 01-05-2006 10:23 PM
help.....critical problem Raaza QnA (read only) 6 22-09-2005 03:37 PM
Critical problem, Help bukaida QnA (read only) 1 28-07-2005 09:45 PM
Help regarding Windows Critical Updates khattam_ Software Q&A 3 16-04-2005 09:03 AM
Critical Lan Problem superuser Networking 1 26-01-2005 08:25 PM
- by kool
