Old 13-10-2007, 02:30 PM   #1 (permalink)
Exclamation DVD Writer probelms
HI all
I am using Liteon DVD writer
The problem is that some of my dvds are not even detected by it
It's not like that none of the dvds are dectected, but few
These undetectable dvds include Digit's also (Apr 2007, Jul 2007, Oct2007). But the same digit dvds runs fine on my friend's Sony DVD writer.
Also I observed that two of my dvds running fine on my DVD writer (Liteon) are not detected by his DVD writer (Sony)
Can anyone please tell me what's the reason, I am frustated with this problem.
Thanks to all
Lalit.
lalit_nagalkar is offline
Old 13-10-2007, 06:04 PM   #2 (permalink)
assasin's Avatar
Default Re: DVD Writer probelms
if a firmware update solves the issue then its ok.else u cant do anything.
assasin is offline
Old 16-10-2007, 11:35 PM   #3 (permalink)
well thanks for sugn
but how to flash the DVD R/W flash
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
CD Writer glass Hardware Q&A 11 27-02-2007 06:43 PM
prb with DVD WRITER sohin Hardware Q&A 4 25-02-2007 07:45 PM
HP CD-writer and Win XP Simple_Graduate Hardware Q&A 1 08-07-2006 09:51 AM
Which DVD writer should I buy? abhinav QnA (read only) 29 07-12-2005 09:02 AM
- by kool
