Old 12-10-2007, 01:46 PM   #1 (permalink)
Default XP in two drives!!!
Guys..I've installed winxp in two partitions of my hd(in C:\ and in D:\)
Now during booting two options are coming as usual to select which os i need to boot.
Now what I want is to remove this delection and I want my pc to boot into D:\ directly....What I have to do for that?..
yoursnayak is offline
Old 12-10-2007, 11:58 PM   #2 (permalink)
Default Re: XP in two drives!!!
Open the 'boot.ini' file in your C-drive and remove the first entry found in the 'Operating Systems' section.Also set the 'default' value to the second entry.
Before editing make a backup of the boot.ini file just in case you mess up.
sashijoseph is offline
Old 13-10-2007, 01:12 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
start-->>right click my computer-->>properties-->>advance-->>startup and recovery-->>settings
startup and recovery windows page will open-->>edit
Boot.ini notepad page will open.
There you will find something like this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
delete this line:
save and close notepad
Now in startup and recovery windows-->>default operating system-->>
select windows XP installed in C:\ drive
Time to display list of operating system-->>make it to zero seconds-->>OK-->>Apply -->>Ok
restart your system.
done
ravi_9793 is offline
Old 13-10-2007, 01:20 AM   #4 (permalink)
dOm1naTOr's Avatar
Just a doubt.
If i edit the text inside " " , then it shud appear as it is at boot time. But If we use A bit more words them its displayed incomplete at boot time, means some words ll be missing either from front or rear. Whys it so?
Also is there ny way we can add an image in background at this point[ by giving the file location or somethin in boot.ini].
Even a 256 colour image wud do.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 13-10-2007, 01:26 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by aravind_n20
Just a doubt.
Simple dear, Because word length is limit.
I am scared, there is no way to add image as background during OS selection.
Yeah, you can have change image of login screen.
Old 13-10-2007, 01:34 AM   #6 (permalink)
dOm1naTOr's Avatar
But sometimes if we use less characters than default, then also it happens. And sometines if we use many words without space in b/w them then it wud be accepted. So its not coz of word limit i think.
G3: XPS M1530 |
FZ 16.
DVD drives hel_cell QnA (read only) 2 26-03-2005 01:29 AM
USB drives 512 to 1GB HELP!!!!!!!!!!!! dOm1naTOr Peripherals 5 05-03-2005 01:31 PM
Pen Drives shyamthakkar QnA (read only) 9 09-11-2004 10:49 PM
Digit's DVD drives the market's drives shakshy QnA (read only) 3 30-10-2004 09:27 PM
- by kool
