Old 12-10-2007, 10:52 AM   #1 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default SMPS+some other questions
Ok guys help me out.I am upgrading my system and I also need to buy a new SMPS.Budget is minimal.here are my alternatives:
1.                                            2.
Zebronics ZEB-400W -                    Zebronics ZEB-400W -
Specs:Zebronics ZEB-400W
+12V: 20A                                    +12V: 10A
+5V: 30A                                      +5V: 14A
+3.3V: 28A                                    +3.3V: 14A
+5Vsb: 2A                                     +5Vsb: 2A
-12V: 0.8A                                    -5V: 0.5A
20-Pin ATX12v                               -12V: 0.5A
                                                   24-Pin ATX12v
Price is around Rs500 for both
Here are my specs:
Intel c2d proccy e6300
Intel 946gzis mobo(sux bigtime)--.http://www.intel.com/products/mother...GZTS/index.htm
2x1gb transcend ddr2 RAm @667mhz
LG dvd-rw
1x80gb sata(wd)
1x250gb sata2(seagate) (ordered)
creative 2.1 speaker system.
XFX 8600gt 256mb(will buy it soon)
From motherboard's Manuel:
The 2 x 12 pin main power connector on the desktop board is backwards compatible
with ATX12V power supplies with 2 x 10 connectors.
Connecting Power Supply Cables
1. Observe the precautions in "Before You Begin" on page 23.
2. Connect the main power supply cable to the 2 x 12 pin connector.
3. Connect the 12 V processor core voltage power supply cable to the 2 x 2 pin
connector.
and here is a pic.:
Now the questions:
1.which one of the above is more suited for my system?please see the above image and quote.This 2x2 connector is alien to me.
2.
Originally Posted by manuel
The desktop board supports four Serial ATA channels (3.0 Gb/s) via ICH7, connecting
one device per channel.
Now as far as I know only sata2 supports 3gbps but sata2 in not mentioned in the manuel.What does it mean?My mobo supports sata2 or just sata1?
Thats it.Please make quick replies.I will buy this monday.
somebody help me.
Stealing your women and horses since 1843.
Last edited by The_Devil_Himself; 12-10-2007 at 10:52 AM. Reason: Automerged Doublepost
The_Devil_Himself is offline
Old 12-10-2007, 11:01 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: SMPS+some other questions
@The_Devil_Himself
da details bout Zebronics norml 24pin 400w model isn't rite. It has some 17 or 18A on 12v rails.
It cud easily handly the load of ur system. Go for it. If u have lil more to spend, then get Zeb platnum 400w for 1.3k or platinum 500w for 1.9k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-10-2007, 11:07 AM   #3 (permalink)
what about that 2x2pin connector in addition to 20\24 pin connector?
Old 12-10-2007, 11:23 AM   #4 (permalink)
dOm1naTOr's Avatar
Nowaays every PSu has that 2x2 pin CPU connector. Zeb too has it.
G3: XPS M1530 |
FZ 16.
Old 12-10-2007, 11:36 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
+12V: 10A
+5V: 14A
+3.3V: 14A
+5Vsb: 2A
5V: 0.5A
12V: 0.5A
This data is certainly wrong. Check for the correct values again. I don't think a modern computer will power up with just 10A on the 12V rail!
infra_red_dude is offline
Old 12-10-2007, 12:02 PM   #6 (permalink)
^^Hmm...let me check it out.
Sounds good but there is no difference between this and the ones I mentioned as far as the railing currents are concerned then why the price difference?
Old 12-10-2007, 12:27 PM   #7 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
^^ i bought 2 cheppo odyssey 500w SMPS for RS 600/- each last dec from computer empire (2x2 pin connector + 24 pin connector)& they are really working fine. can give u ratings when i reach home if u want.
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 12-10-2007, 12:29 PM   #8 (permalink)
^^please do.
I am now seriously considering ZEb 400w platinum but 1.3k sounds too much for a SMPS.lol.
Old 12-10-2007, 12:31 PM   #9 (permalink)
dOm1naTOr's Avatar
@The_Devil_Himself
platnum series are more efficient nd reliable. It can be compared with say a 550w loacl SMPS.
For eg; CoolerMaster 400W is better than even local 600w PSU.
G3: XPS M1530 |
FZ 16.
Old 12-10-2007, 12:50 PM   #10 (permalink)
shadow hunter
Originally Posted by aravind_n20
@The_Devil_Himself
@devil yes this is exactly true. local smps cant handle over clocked configs.
i think a local 500w smps can handle ur config at stocks only.
actually before buying smps i gave my config to that fair guy with lenses at computer empire and asked him whether that smps can handle it at stocks and he said yes.thats it !!
Old 12-10-2007, 01:28 PM   #11 (permalink)
My current mobo(Intel 946gzis) doesn't allow overclocking but I am surely gonna buy XFX 650i ultra a soon as my budget allows(maybe january not sure though).Now what you guys suggest.
Old 12-10-2007, 01:51 PM   #12 (permalink)
dOm1naTOr's Avatar
@The_Devil_Himself
if dats da case, then get Zeb Platinum 500w. U can easily oc da proccy, mem nd gcard with that. It has gud cooling too with a 120mm LED fan.
It has:
+12v:22A
+3.3v:24A
+5:26A
-12v:0.8A
-5v:0.5A
+5VSB:2.0A
This is enuf for cards upto 8800GTS 320
G3: XPS M1530 |
FZ 16.
Old 12-10-2007, 01:52 PM   #13 (permalink)
u shud get at least Colorsit 500 Watt PSU.it will help u in future when u add extra hdd,optical drive,may be better gfx card,etc.
zeb 500 watt wil also server ur purpose.bt plz, dont compromise on psu.
and if ur going to get XFX 650i Ultra in near future for oc, u ll definitely need a good PSU.
DOTA is really addictive :D
BULLZI is offline
Old 12-10-2007, 01:57 PM   #14 (permalink)
damn busy...
utsav's Avatar
whats d price of zeb 500W and colorsit 500W
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 12-10-2007, 02:05 PM   #15 (permalink)
assasin's Avatar
i dont think that Zeb Platinum 500w will pwr a 8800GTS 320MB cuz the recommended rating on the 12v rail is 26A for the 8800GTS.
i've used the Zebby 400w psu with 20a on the 12v rail and it has a 20+4pin connector for the mobo.i dont know why most ppl report that it has a 20pin connector.its a very good psu in the 500 bucks range.easily handled my E4300 oc'd to 3GHz and my 8600GT oc'd to 720|1650|1700.
Zeb Platinum 500w will cost bet 1.7-1.9k and Colorsit 500w sud be within 1k.
assasin is offline
Old 12-10-2007, 02:49 PM   #16 (permalink)
Now consider the following to be my final system:
c2d e6300
XFX 650i Ultra
1x2gb ddr2 RAM
1x80gb SATA
1x250gb sata2
lg dvd-rw
XFX 8600gt
Now which smps should I buy.I will overclock my system(thats why i am gonna buy 650i ultra).Again costs should be minimal.
Old 12-10-2007, 03:01 PM   #17 (permalink)
dOm1naTOr's Avatar
I think ur system wud need a min of Zeb Plat 500W. Orelse get CM or Powersafe. But again cost will be 2k+
G3: XPS M1530 |
FZ 16.
Old 12-10-2007, 04:59 PM   #18 (permalink)
@utsav
cost of Zeb 500 watt given above by Aravind.
my previous PSU was Colorsit 450 watts that cost 1.3k along with cabby.
BULLZI is offline
Old 12-10-2007, 06:36 PM   #19 (permalink)
shadow hunter
Originally Posted by The_Devil_Himself
^^please do.
odyssey 500w model : KY-600ATX
+5V: 38A
+12V:17A
-5V: 0.5A
-12V: 0.8A
+3.3V: 28A
+5Vsb: 2A
although ratings of local smps are always susceptible .
Old 12-10-2007, 06:41 PM   #20 (permalink)
I think i will buy zeb 400w platinum@1.3k.wont go for 500w(1.7k)platinum cos I won't be upgrading my system for 2-3 years after this upgrade.
can somebody confirm the prices?
SMPS got a Boo Boo :( Thor Hardware Q&A 4 13-04-2007 09:26 AM
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
Wat Smps should i get ArZuNeOs Hardware Q&A 9 23-10-2005 11:26 PM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
- by kool
