Old 11-10-2007, 06:08 PM   #1 (permalink)
Kalyan's Avatar
Question Need help abt buying PSU
Hi all..
My pc config is in my sig.. I bought the 8600GT 256MB recently. But I am using it with my 400W stock PSU given with the cabby. So far, the games are running good on high settings. I havent encountered problems. The temperature is nearly between 60-70 for the GPU. I am planning to get a new 1GB 800MHz RAM for my pc. Do I need to upgrade my PSU? Would I get any problems with the 400W one or could I continue with this setup? If I need to, Please suggest me which PSU would be better for me?
I enquired the shopkeeper and he showed the zebronics 500W one for 2300. He didnt have 600W ones. He had some 550W ones also but I dont remember the price he quoted. How much would the PSU cost? Please suggest..
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 11-10-2007, 06:21 PM   #2 (permalink)
Cool G5's Avatar
Default Re: Need help abt buying PSU
Yes go for Zebronics 500 watts,it's enough for your system.The price the dealer gave you is right.Don't look for 600w it will be a waste of money.
Cool G5 is offline
Old 11-10-2007, 10:11 PM   #3 (permalink)
why bother if ur current psu is managing well ? a better psu is always better but i dont think ur current psu can do harm . . get a new one , if something appears to be "not rite" .
sagargv is offline
Old 11-10-2007, 10:42 PM   #4 (permalink)
dOm1naTOr's Avatar
Its better to upgrade ur PSU as ur system seems a bit heavy on power. A Zeb 500W platinum is more than enough for ur rig. But the price quoted is a bit high. I bought Zeb 500W platinum 3 months back for 1850/- incl tax. Its enuf for cards upto 8800GTS 320MB.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
RAM buying help swaroop123 Hardware Q&A 1 27-06-2007 01:30 PM
RAM buying int86 QnA (read only) 9 22-01-2007 06:11 PM
Need help in buying RAM. risqer QnA (read only) 23 18-05-2005 04:13 PM
buying a new pc ... megacoolxs QnA (read only) 4 13-04-2005 10:00 PM
- by kool
