11-10-2007, 07:34 AM
1.5 GB ram?
guys i have a 1x512 mb 667 mhz ram
i am going to buy more memory soon
now should i buy 512 mb ram or 1 gb ram.
if i buy 1 gb will i be able to dual channel it?will i face any problem later on(ram failure etc)
thank you
11-10-2007, 08:47 AM
TechTin.com
Re: 1.5 GB ram?
buy 1 GB if you don't have money problem.
Before that make sure ur motherboard support memory upto 2 GB.
11-10-2007, 08:54 AM
left this forum longback
Re: 1.5 GB ram?
try to buy the same model/brand of RAM.
11-10-2007, 09:01 AM
TechTin.com
Re: 1.5 GB ram?
Brand does not matter..but the new RAM should of of same type (DDR or DDR2)....and of same frequency.
11-10-2007, 09:02 AM
Re: 1.5 GB ram?
yes supports upto 2 gb and also supports dual channel.
will i be able to run 1.5 gb in dual channel?
11-10-2007, 09:04 AM
TechTin.com
Re: 1.5 GB ram?
no........
U cant run in dual channel mode..with different RAM memory.To run in dual channel mode, both RAM should be of same memory.In your case, the new RAM should be of 512 Mb, to run in dual channel mode.
11-10-2007, 10:31 AM
Re: 1.5 GB ram?
go for another 512 MB ram of same frequency as well as latency.that will be more suitable for u rather than going for another 1 GB ( u ll be able to hv dual channel mode ) and its also cheaper  .
DOTA is really addictive :D
11-10-2007, 11:04 AM
Re: 1.5 GB ram?
but will it perform better than 1.5 GB even without dual channel?
11-10-2007, 11:16 AM
gooby pls
Re: 1.5 GB ram?
Dual Channel just increase bandwidth.
Go for 1 GB.
11-10-2007, 11:22 AM
Re: 1.5 GB ram?
if possible sell ur 512 stick andget 2 *1 gb sticks ............
11-10-2007, 11:30 AM
TechTin.com
Re: 1.5 GB ram?
thats cleaver idea
11-10-2007, 11:33 AM
Re: 1.5 GB ram?
+1
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
11-10-2007, 01:29 PM
Re: 1.5 GB ram?
Go for 1 GB.
increased bandwith will definitely make the system faster.
anyway, if he can sell his 512 module and buy 2*1 GB, tht will be the best  .
11-10-2007, 01:34 PM
Bond, Desi Bond!
Re: 1.5 GB ram?
yes. Sell the existing 512MB and get two 1GB sticks.
Yesterday, I bought 1gb ddr2 667Mhz Transcend ram (single stick) for Rs.1222 in Bangalore
11-10-2007, 06:04 PM
Re: 1.5 GB ram?
ya but ram prices being as they are i dont think any1 will buy old ram!
11-10-2007, 06:34 PM
TechTin.com
Re: 1.5 GB ram?
sell at very low price.
11-10-2007, 06:50 PM
Re: 1.5 GB ram?
11-10-2007, 10:16 PM
Pee into the Wind...
Re: 1.5 GB ram?
Having two RAMs of different sizes in dual channel mode is not a nice idea.Even I used to have 1gb + 128mb RAM thinking that more RAM = better performance...to hell with dual channel,same latency etc. etc. etc. crap.But someone advised me to remove the 128mb stick.Followed his suggestion and noticed a nice boost in performance.  .
If you do go in for dual channel,make sure you get both RAMs of same company and,preferably,same size too...
Life is as complicated as you say it is.
11-10-2007, 10:27 PM
#19 (permalink)
TechTin.com
Re: 1.5 GB ram?
company does not matter...
Frequency should be same.
11-10-2007, 11:18 PM
#20 (permalink)
Re: 1.5 GB ram?
They MUST be of the same size ... my mobo manual clearly states it.
11-10-2007, 11:28 PM
#21 (permalink)
TechTin.com
Re: 1.5 GB ram?
yes..agree with you.
To run in dual channel mode, size of both RAM should be same.
13-10-2007, 02:21 PM
#22 (permalink)
Re: 1.5 GB ram?
i think ill just go for 1gb now and buy another 1gb around diwali!!
