Old 10-10-2007, 11:27 PM   #1 (permalink)
Default ram compatibility
hi...right nw i've 512mb ddr2 ram wth 667mhz..want to upgrade retaining d one i've right now..as derz small price diff btwn 512mb n 1gb,want 2 go for 1gb..'ll it work if i place 1gb stick along wth my present 512mb ddr2..plz help wth dis....
prasanna munoli is offline
Old 10-10-2007, 11:48 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: ram compatibility
it'll work as long as you use the same frequency(i.e. 667mhz) stick.If you use two different frequency RAMS then you may get frequent BSODS.
BTW.I suggest you either go for 2x512mb or 2x1gb if your motherboard supports dual channel RAM.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 11-10-2007, 12:40 AM   #3 (permalink)
Nav11aug's Avatar
if you pair up the 1 GB with a 512MB one, you wont get your full performance. check up you mobo manual, it is mentioned fr sure
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
ram compatibility rahul30 Hardware Q&A 7 10-06-2007 05:19 PM
RAM compatibility vish1988 Hardware Q&A 8 26-12-2006 11:20 PM
64 bit compatibility vipashdigit QnA (read only) 4 29-11-2006 11:39 PM
RAM compatibility Help d33p4k Hardware Q&A 14 07-03-2006 02:50 PM
RAM Compatibility..... justo QnA (read only) 2 03-12-2004 10:32 PM
- by kool
