Old 10-10-2007, 04:49 PM   #1 (permalink)
mayneu's Avatar
Red face best mobo+pro combination for AMD???
i want to upgrade my pc, so i thought i would consult people over here before doing t hat. so guys pla advice me on best mobo+pro combination for AMD. my budget is around 6k +/- 2k. it should be less than 10k. because i want to buy ram also DDR2 667 mhz. all these should fit under 10k budget.
i want help only for mobo+pro pls.... it should have a best performance...... waiting forur reply guys.....
mayneu is offline
Old 10-10-2007, 11:34 PM   #2 (permalink)
Default Re: best mobo+pro combination for AMD???
Asus M2A-VM (AMD690G northbridge,X1250 graphics,DVI interface.......)
X2 4400+
Total ~7.5k
sashijoseph is offline
Old 10-10-2007, 11:38 PM   #3 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
+2.5k for 2gb transcend ddr2 RAM 667mhz.Perfect 10k.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 11-10-2007, 12:45 AM   #4 (permalink)
Nav11aug's Avatar
Athlon64 X2 6400+ is good value for money i heard , is it ?
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 11-10-2007, 01:20 AM   #5 (permalink)
Rubik's Uncle!!
Charan's Avatar
X2 4400+
Total ~7.5k
There is a new model available M2A-VM HDMI , this mother board has got a additional daughter board which has HDMI port , S-Video, and composite output. The preformance has been reported as very good. Real value for money.
Charan is offline
Old 11-10-2007, 02:24 AM   #6 (permalink)
The Transcendental
M2a Vm Hdmi + X2 4000+
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 11-10-2007, 02:55 AM   #7 (permalink)
Ex-KGB
Asus M2A-VM and AMD 64 X2 4400+
7099 ( tax included ) from Delhi 2-3 weeks ago
avikchaks is offline
Old 11-10-2007, 08:33 AM   #8 (permalink)
IIRC the HDMI card occupies the PCIe-16 slot and you cannot use a graphics card along with it.
V.Prem Kumar
janitha is offline
Old 11-10-2007, 10:01 AM   #9 (permalink)
mayneu's Avatar
thanks guys.... i appreciate your efforts
mayneu is offline
Best AMD Processor & MoBo Combination for my new PC? Ramstrong Hardware Q&A 20 27-10-2006 06:50 PM
Suggest ASUS mobo + AMD 64 fx best combination boomstation2 Hardware Q&A 27 21-09-2006 05:04 PM
AMD 3800 X2 + good mobo combination praway Hardware Q&A 6 21-09-2006 04:29 PM
Best Mobo+Processor combination for AMD... White`Knight Hardware Q&A 30 18-03-2006 12:28 PM
processor and MOBO combination sav_more CPU / Motherboards 17 18-08-2004 02:38 AM
- by kool
