Old 10-10-2007, 10:41 AM   #1 (permalink)
Default Suggest a decent soundcard!!
I need a decent 8 channel soundcard. Budget 10 k max.Please suggest.
thanx in advance.
DOTA is really addictive :D
BULLZI is offline
Old 10-10-2007, 10:46 AM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: Suggest a decent soundcard!!
Sound Blaster X-Fi Fat1lity.Will fit within ur budget.
Link
Harvik780 is offline
Old 10-10-2007, 10:55 AM   #3 (permalink)
is it really good? sorry for asking the question bt its always better to choose from a no. of options,isnt it?
BULLZI is offline
Old 10-10-2007, 10:58 AM   #4 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Has been recommended by guru3d.
Old 10-10-2007, 01:39 PM   #5 (permalink)
ok thanx buddy.let me check that out..
BULLZI is offline
SUggest a good decent digital video recorder NiluGeek Software Q&A 2 20-08-2007 07:59 PM
please suggest a decent cpu cooler BULLZI Hardware Q&A 46 16-07-2007 11:49 AM
Soundcard Compatibility thrash_metal QnA (read only) 2 30-05-2006 08:42 AM
soundcard problem sridhar8310 QnA (read only) 4 14-09-2004 04:48 AM
- by kool
