Old 08-10-2007, 10:46 PM   #1 (permalink)
Default I can not insatll windows vista on my system
hii , i am jitendra from india
"i can not install windows vista on my system."
my system configuration
intel pentium d 2.67ghz,1mb l2 cache
intel d945gnt motherboard with windows vista premium ready
transcend 1gb ram
samsung 80gb hdd
" whenever i tried to install vista , installation is completed but when pc restart and blue screen will appear(very few seconds).then error will generate
i found this error :
the computer has encountered unexpected error. To install vista press ok and install vista again. "
i am also try to install vista on another harddisk(segate) but same error will generate.
plz help me.
i hope you reply me as soon as possible
jitendrapatel005 is offline
Old 08-10-2007, 11:46 PM   #2 (permalink)
We Both Have a Mouse!!!
nishantv2003's Avatar
Default Re: I can not insatll windows vista on my system
i think there may be some prob in ur gfx card or vista installation cd..
check installing it on another system, also try adding a seperate gfx card and try to install again..
nishantv2003 is offline
Old 08-10-2007, 11:54 PM   #3 (permalink)
moshel's Avatar
1. take out the ram module, clean it and put it again.
2. do the same with the graphics card
also format the partition in which you are going to install vista, before installation.
moshel is offline
TUTORIAL: Small Processor Trick to Improve System Performance in Windows Vista Vishal Gupta Tutorials 28 12-01-2009 03:05 PM
I can not insatll windows vista on my system jitendrapatel005 Software Q&A 1 09-10-2007 09:25 PM
I can not insatll windows vista on my system jitendrapatel005 Software Q&A 1 09-10-2007 09:24 PM
i can not install windows vista on my system jitendrapatel005 Chit-Chat 2 07-10-2007 05:10 PM
- by kool
