Old 07-10-2007, 01:41 PM   #1 (permalink)
Novice
Unhappy No Display in Monitor
hi all
i assembled a PC some 6 months back.. an Asus M2N MX motherboard, AMD 3800+ , zion 512MB x2 DDR2 RAM, Samsung 160GB HDD, LG Flatron CRT.
A few days back, the screen suddenly hanged. neither the keyboard nor the mouse was working. when i had to reboot, there was no display. no sound is coming out either. the power light of the monitor is just blinking on and off, like in standby mode.
pls suggest what to do. i hope i have been able to describe the problem properly..
thanks in advance.
regards
Soumyajit
Soumyajit is offline
Old 07-10-2007, 07:06 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: No Display in Monitor
there can be many reason. first check SMPS
Does the SMPS fan swing when you give power??????
ravi_9793 is offline
Old 07-10-2007, 07:41 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Most probably its the ram.try replacing it with another
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 07-10-2007, 08:36 PM   #4 (permalink)
"The Gentleman"
vish786's Avatar
tell ur problem in detail.... when does it hang... which OS... hangs after using ur comp for sometime... or before booting into any OS... if u really want an solution then its better 2 provide all pariticulars
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 08-10-2007, 04:49 PM   #5 (permalink)
@ soumyajit,
hi...I'm a noob myself...but i've faced this problem too and here is what i think is the solution...try it out..
I believe the problem is because of conflicting drivers ..the motherboard video driver and the video card driver. You'll have to disable one of them...preferrably the on board ones from bios setup. as for switchin on your monitor now...this is what i did...I disconnected the monitor jack from behind the cpu and switched on the system ( by this time your monitor should be displayin " No signal detected" or something to that effect ) continue booting that way and once you are at the windows welcome screen or desktop ( you'll know where you are from experience ) reconnect the monitor cable..your display should come on...it worked for me..I hope it does for you...
regards
Forgiveness is the fragrance that a violet sheds on the heel that crushes it. To Forgive calls upon your love, to forget calls upon your strength.
anna_don is offline
Monitor display is all Pink. Neha.N Hardware Q&A 15 29-03-2006 06:03 PM
Monitor can't display graphics! Satissh S Graphic cards 2 25-12-2005 10:10 PM
monitor not starting - no display - nothing???? sincereheart QnA (read only) 7 26-05-2005 05:39 PM
Monitor display is PINK :( foreveranuj QnA (read only) 7 02-02-2005 10:43 PM
Monitor Display Problem daumaster QnA (read only) 5 07-10-2004 01:48 AM
- by kool
