Old 06-10-2007, 11:11 AM   #1 (permalink)
Devrathnd
Posts: n/a
Default buying LAPTOP
Dear freinds I want to buy a laptop which has all these features
80 Gb HD
Bluetooth
Wifi
dvdrw
I will be using it mainly for showing videos and pictures through projectors and for basic office usage
Old 06-10-2007, 11:18 AM   #2 (permalink)
Nav11aug's Avatar
Default Re: buying LAPTOP
I do recommend HP , just chk out these two links.
http://h50036.www5.hp.com/products/hppav_ntp.asp
http://h10010.www1.hp.com/wwpc/in/en...7-1116665.html
for HP's laptops. I'm surprised HP's India site does not offer customizable lappys.
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 06-10-2007, 11:23 AM   #3 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Hmm. Choto Cheeta had done a good review of Acer 4710z, Search the Forums
Features:
Intel T2080 Dual Core Proc
1GB RAM
14.1" Widescreen LCD
8x DVD-RAM Drive
Wi-Fi, Bluetooth
160GB HardDrive
Costs around 32-35k.
Edit: See this-> Quick look at Budget Laptop / Notebook Acer 4710z
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 06-10-2007, 12:00 PM   #4 (permalink)
Devrathnd
Posts: n/a
my budget is below 40000
Does this suit my requirement and does it have wifi and bluetooth. A dealer quoted me
lenovo 3000 n100 0768AQ1
Help Buying a Laptop shivkumar Laptops and Netbooks 1 05-10-2006 05:22 PM
Need help in buying Laptop!! nach p Laptops and Netbooks 1 18-09-2006 03:57 PM
buying LAPTOP salils Hardware Q&A 1 12-07-2006 05:21 PM
buying a laptop plasmafire QnA (read only) 33 27-01-2005 04:17 PM
- by kool
