Old 04-10-2007, 09:47 PM   #1 (permalink)
Post catch 22 situation
hi friends,I'm using a 256MB SDRAM & my motherboard doesn't support a DDR RAM;so shud i upgrade my SDRAM(which is outdated or being phasd out)or shud i go & buy a new motherboard & a DDR(finanacial constraint)so plzzzzz suggest me the best possiblity
murali_crst is offline
Old 04-10-2007, 09:57 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: catch 22 situation
Go for a motherboard supporting ddr2 RAM.They are available for as low as Rs.3k.Then you can sell off your current RAM module and gor for even a gb of ddr2 RAM(around 1.2k)
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 04-10-2007, 10:05 PM   #3 (permalink)
An extra 256 MB SDRAM will set you off by about 1 k while adding 512 MB SDRAM will set you off by about 2k... If you are using XP or older version of windows, or perhaps linux, and dont use any very-intensive software, you should stick with the current config and upgrade just the RAM for now...
Arun
sakumar79 is offline
Old 04-10-2007, 10:06 PM   #4 (permalink)
The Transcendental
^ I was in the same fix 1 month ago.
I checked SDRAM prices in NP and was appalled to learn that SDRAM has almost disappeared from the markets.
The few distributors who can source it from the manufacturers wanted d pound of flesh in return.
You are better off buying a new mobo, proccie and RAM. I just upgraded.
If you want SDRAM and are based in Delhi, perhaps i can sell you mine cheap. But first, check the markets for the price and tell me how much you are willing to spend and then decide if you are ready to upgrade now or wait a few months.
If the latter, I advice atleast wait til november for the Penryn core intel processors, Barcelona from AMD and the X38 mobos. Their launch will have a trickle down effect on every other product in the markets and you may get upgrades cheaper.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 04-10-2007, 10:08 PM   #5 (permalink)
I too advise you to wait till november end to make your upgrades.In the meantime save some more and keep an eye on Bazaar section.
I m confused in a situation.. Please help me to get out of it arunks QnA (read only) 11 30-09-2007 07:28 PM
***Hard Disk Crash Grave Situation **** soumendra Hardware Q&A 3 01-06-2007 10:41 PM
Landed really in wierd Situation freshseasons Networking 9 17-01-2006 07:49 AM
Peculiar Situation How to install linux ? cyberia.in Open Source 5 30-09-2005 10:03 PM
HELP..NEED....URGENT....MOTHERBOARD...! DO or DIE SITUATION ragsbava CPU / Motherboards 6 18-07-2005 09:09 AM
