Old 04-10-2007, 01:08 PM   #1 (permalink)
Proud to be Linux
abhinandh's Avatar
Default bios checksum error
i get this error when i start my computer.cmos battery is not faulty.date and time are correct.using an intel 845 mobo.
http://abhinandh.com
abhinandh is offline
Old 04-10-2007, 04:24 PM   #2 (permalink)
shantanu's Avatar
Default Re: bios checksum error
check your motherboard manual as the jumpers for clearing the data seems to be short.. this happens in this case only..
shantanu is offline
Old 04-10-2007, 06:34 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
Power Down Your Comp completly.
Locate The big sized battery ( ie CMOS battery) on the motherboard.
Remove the battery & after about a minute later put it back on.
This will put your mobos settings to default.
Your problem should be solved. If not try to replace the battery.
They will cost you Rs. 8-10.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 04-10-2007, 06:47 PM   #4 (permalink)
shantanu's Avatar
Smile Re: bios checksum error
i guess you didnt read the question fully ? he says battery is ok.. and date and time are also ok.. ? that means the jumper is set wrong !
shantanu is offline
Old 11-10-2007, 05:32 PM   #5 (permalink)
Back in Power
almighty's Avatar
hey i also get the same error
"CMOS checksum errors" and am unable to boot ... but after some tries it booted but dont know why it happened...
what sud i do to protect my pc or how can i know whats fault dere ...
either ram or battery...
It happens always once in a month or two ,and after some retried pc boots...
today i just clean my pc (from outside) and when i boot my pc it refuse with a beep
kindly help me to find out the error... its battery error or ram error....
how to check my ram? is dere in testing s.w for that?
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 11-10-2007, 06:19 PM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^Exactly the same problem that i faced 1 mnth ago..without no reason cmos cheksum error comes in....one day it refused to boot.
now its ok , mb got serviced.....he said its the problem with power controller ic
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 11-10-2007, 06:36 PM   #7 (permalink)
Back in Power
almighty's Avatar
OMG :O u mean i ve problem In MB
any s.w for testing ram?????
one thing i observe today , while re-seat-ing all my hardwares, I boot without graphic card and it booted ....
and dereafter i inserted graphics card and it get booted...
u know when i boot my pc while it was not placed properly coz of open cabinet , I press the button and it boot up so i thot the problem is over now and i mounted cpu at dere place....
I am very much happy that my pc is working fine agian but when i press after mounting my cpu properly it again wont boot ...
LOL
what i feel that time i cant tell u ....
again i tried it with open cabinet and it booted
don know why it happened
LOL
almighty is offline
Old 12-10-2007, 08:28 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
I have faced this issue with my mercury 845 mobo. Just re-sit your ram and gfx cards properly & clear the cmos setting by jumper or by removing cmos battery & put it back again. Yours problem should be solved
topgear is offline
Old 12-10-2007, 11:09 PM   #9 (permalink)
Back in Power
almighty's Avatar
ya ryte said mate... exactly the same way I done and my pc is fine now
almighty is offline
BIOS Bad Checksum valtea QnA (read only) 11 26-04-2007 02:38 PM
Bios Checksum Error... deepak_vsoni Hardware Q&A 4 20-11-2005 07:30 PM
BIOS Checksum Error ... jay4u QnA (read only) 6 23-03-2005 07:47 PM
CMOS CHECKSUM ERROR Aseem Nasnodkar QnA (read only) 3 19-09-2004 08:10 AM
CMOS CHECKSUM ERROR tirthasanyal QnA (read only) 7 21-08-2004 06:50 PM
