Hi !
This is Bhaskar from kolkata. I am a regular reader of digit magazine. recently I faced a piculiar problem with my computer. Before explain it , I give the configuration of my pc
Processor – Core2Duo 1.86 Ghz, Motherboard – intel DG965WH, RAM – Xeon 1 GB DDR2 HDD – seagate 160 GB SATA, Monitor – Asus 19” LCD wide screen(VW192) max resolution 1440X900
My problem is I cant set the correct resolution (1440X900) for my monitor. I am not facing this problem from starting. At earliar I have two operating systems i.e win2000 an win xp pro.in different drive. And it running fine with correct resolution (1440X900) and windows autometicaly detect it when I install graphics driver software. But in last sunday morning when I boot win XP it give flikker image and I found resolution is not correct . So I try to set resolution in display properties but it is not in the list. Then I boot anather Operating sys for checking (win2000) but here also the same problem exsist so I quite ensure that it might be hardware problem. That system cant recognisied the right monitor type.( there is no driver cd comes with my monitor) . I also try by reinstall Windows and graphics driver but it not solve this problem.
I am totally confused . what can I do?
Pls anybody help me if know the way for such problem?
yes it realy a prob to read the post but it's ok i read it .......after having that much pain only i could suggest u that try to use ur monitor on some other pc will it work fine on that if it then to find proper driver for ur monitor on net ........
Be original use pclinuxos ........
www.pclinuxos.com
