Old 02-10-2007, 08:53 PM   #1 (permalink)
Jags's Avatar
Question weird copying speed with usb 2.0 :(
I plugged in my usb-cased laptop hdd into of the PCI usb2.0 card's slot.
now when im copying my data INTO the usb-hdd its copying damn fast (10 secs for 200MB)
BUT
when im copying data FROM it, its really slow (2 mins for the same file)
any clue why this is happening?? ?-(
--> wasnt sure if this to post this in s/w, QnA or h/w.. mods plz move this thread to the correct one
Jags is offline
Old 16-10-2007, 04:50 PM   #2 (permalink)
Mark0's Avatar
Default Re: weird copying speed with usb 2.0 :(
Uhm... Maybe when you write on the HD, Windows is able to cache almost the entire file; if so, while it seems it have finished copy, there's still data trasmitted to the HD for some times.
Are you sure you are using a proper USB Hi-Speed cable? A non compliant cable will cause a lot of retries / retransmission and thus lover the speed.
Bye!
Mark0 is offline
Old 16-10-2007, 11:30 PM   #3 (permalink)
Jags's Avatar
Bye!
wel d problem got solved..i jst changed the pci port..and it works fine now..
thanx for ur reply
Jags is offline
Tokyo boffins crack internet speed record - reached 7.67Gbps speed! Kiran.dks Technology News 35 19-10-2007 01:16 AM
utorrent prob, upload speed is higher than download speed daemon Internet & WWW 2 17-07-2007 03:05 PM
copying .swf aakash_mishra Software Q&A 18 07-12-2006 04:43 PM
copying dvd to cd... abhishekkalra QnA (read only) 2 27-12-2005 06:35 PM
