Hi Guys,
I built my new pc yesterday. After assembling the pc I started but nothing is happening. No beep is coming from the system.
The config is :
Intel dual core E2140 1.6 GHz
Mercury mainboard with 945 chipset
Dynet ram 1GB @667MHz
Segate Sata2 250 GB
LG 17'' lcd
I checked all connections and they are fine. Processor fan starts immediately after power on but then nothing comes on the screen.
I later removed all devices(like hdd, dvd writer etc) connected and kept only processor and ram on the board but the same story. Later I changed the ram slot but to no avail.
I guess that there is some problem with the mainboard/ram as no beep is coming from the system speaker.
As I know even if there is a problem with the ram the bios and all comes on the screen and then u get some error if its a faulty ram. Am I right/wrong?
I am unable to figure out what might be the problem.
Please help asap! Thanks in advance!
Regards,
Amit Kale.
