Old 30-09-2007, 06:17 PM   #1 (permalink)
Default Problem With My New MP3 Player - help me ASAP
I have recently bought apro multimedia player Model - MP-838FSC. And i found tat there is a update for the firmware is available at http://www.eurone.com.hk/support.html .
now i get a strange problem ....
I downloaded the firmware from their site... as i dono wat to do with it, i just opened all the files n done some thing that shouldn't be done ... now i dont get my mp3 player get started ... also earlier there where 2 drives(j,k), but now there is only j: n even tat doesn't seams to open..
Some1 please help me out.... Iam crying for it now
exactly wat i done is, i copied the firmware files to j: n i opened every files.... tats it every thing is gone
Can i get my player working again??? please help me out....
Please reply as soon as possible....
Thanks in advance...
navino87 is offline
Old 01-10-2007, 01:31 AM   #2 (permalink)
ayush_chh's Avatar
Default Re: Problem With My New MP3 Player - help me ASAP
if u hav not tried this then pls try
if u have got some s/w with the player then first uninstall it from ur system....now connect the player to ur PC and format it....remove it from the system, install the s/w again and then try using it...
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 01-10-2007, 07:20 AM   #3 (permalink)
Make sure you have the correct firmware update for your player(there are 3 provided in the site).Extract to the hard disk(and not your mp3 player) and run the factory4.exe
You may also contact the tech support guys here : tech@eurone.com.hk
sashijoseph is offline
Old 01-10-2007, 08:05 AM   #4 (permalink)
@ ayush_chh no software is provided with the player.
@ sashijoseph when i update the firmware, i get an error msg " 6 : Write PM fail".
navino87 is offline
pls help asap artem QnA (read only) 2 23-10-2006 09:14 PM
serious problem, help ASAP imported_tarang QnA (read only) 15 16-05-2006 07:02 PM
serious problem, help ASAP imported_tarang QnA (read only) 3 18-04-2006 12:00 AM
help me asap, what is this? legolas QnA (read only) 7 31-10-2005 04:12 AM
Help ASAP !!! harmik QnA (read only) 27 23-04-2005 03:32 PM
