Old 29-09-2007, 02:36 PM   #1 (permalink)
Unhappy How can I run PC DVD writer on Laptop?
Friends I’m interested in buying a USB dvd writer for my Acer Aspire 5101 laptop, [its build-in DVD writer is not working, and those people even repair it in warrantee period saying that the screw isn’t opening, I mean I had got the RAM upgraded to 512 MB but that computer guy damaged the screw while opening the case and now the Acer warrenty people don’t open the screw and all,anyway that’s a long story and I’ve no time for legal battle with them] so instead I just want to get a new DVD writer, how much a cheap USB DVD writer can cost? [my budget about 1500/-]
I hear that pc DVD writer are cheaper than USB, is there anyway to get the PC DVD writer working with Laptop? If yes then how? And how much does it cost?
# Tell me the cheapest price for brand new USB and PC DVD writers [with good reputation]
Billy155mm is offline
Old 01-10-2007, 04:58 PM   #2 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: How can I run PC DVD writer on Laptop?
bt dont giveup on these ppl [acer] .... just peecha karo & try working the GANDHI - GIRI ....... "get well soon "
yes it will work [usb dvd] ........ get a dvd writter + usb casing 4 it ......
... W H O T ...
ax3 is offline
Old 01-10-2007, 05:07 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
I dont think PC DVD R/W will work on laptops.Better buy a USB drive.
ravi_9793 is offline
Old 02-10-2007, 02:40 PM   #4 (permalink)
Take a PC DVD writer
Get one IDE to USB convertor
I think you will need external power supply for your DVD writer
Now you can use your DVDWriter with Laptop as external driver.
Most of the Laptop DVD/CD writers are USB based only so speed is not an issue.
lilovirus is offline
Old 02-10-2007, 11:09 PM   #5 (permalink)
a_tif's Avatar
buy a casing to make the drive external and use it with ur laptop
u would need to connect it to ir laptop using usb cable n drive will require external power
a_tif is offline
Internal DVD Writer & Laptop - How to use it? SGS_001 Hardware Q&A 3 10-02-2007 05:35 PM
graphics card and dvd writer for my laptop?possible or not? hare81 QnA (read only) 1 14-08-2005 04:13 PM
need to buy a acer laptop with dvd writer mayneu QnA (read only) 10 07-06-2005 12:28 PM
