Old 29-09-2007, 01:53 PM   #1 (permalink)
Default hangs a lot.....need help.........
my pc havin mobo. Gigabyte 81845gv , 2.4 ghz, 2*256RAM......
it hangs a lot...........
i'av tried formatting it several times,
also checked for viruses, spies etc,
checked RAM, SMPS, HDD, Each cable of mobo. evrythin is fine but still it hangs. wats the fuss???????
& is der ny Chip-level repairing shop in MUMBAi???????
tHNX...................
mayhemabhi is offline
Old 29-09-2007, 02:47 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: hangs a lot.....need help.........
Is the problem of hanging system, since you bought ur system.OR have you done any hardware change in ur system??
ravi_9793 is offline
Old 29-09-2007, 03:38 PM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
How old your system is ?
Ones such types of problem is occured in a 5 yrs old PC. I found the problem in HDD where there was some bad sector and once the HDD gone. When I replaced the HDD with a new one. Now the system is no hang also the system became faster than previous.
It may not be in your case. I am saying only my experience regarding that PC.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
WMP 11 Hangs g_goyal2000 Software Q&A 8 26-05-2008 07:58 AM
PC Hangs abhi99_iitg Hardware Q&A 5 30-06-2006 08:39 PM
Hdd hangs up cyrux Hardware Q&A 1 21-06-2006 12:30 PM
nfs mw hangs up!! romeo_8693 Gamerz 10 09-03-2006 11:01 PM
Xp Hangs dando Software Q&A 8 24-03-2005 08:32 PM
