Old 29-09-2007, 12:39 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Need suggestions to buy DVD player
Hi guys,
I'm planning to buy a DVD player. Am looking for a model with USB. Planning to connect my iPod or some other external hard disk via USB.
It should also be able playback DivX and Xvid since I have a large collection of DVDs written with Xvid content.
I heard that Philips models are very good with respect to support for DivX and Xvid. Any suggestions on which DVD player is the best for my purpose ?
gulgulumaal is offline
Old 30-09-2007, 05:38 PM   #2 (permalink)
CA50's Avatar
Default Re: Need suggestions to buy DVD player
hi pal
acc. 2 me there is a samsung DVD player with USB support. check it out
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 30-09-2007, 06:09 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
I too heard Philips was good till two of my friends bought a Philips DVD Player DVP3046/94. Its been two months they bought it and they have already taken it three and four times to the service centre. Yes service is free now , but what about later, after warranty. They have told the service people that they will go to consumer court if it spoils again. Please note that both of them bought from two different locations, one from Bangalore, and one from Mangalore
NucleusKore is offline
Old 30-09-2007, 11:26 PM   #4 (permalink)
dattebayo
anispace's Avatar
never faced any such problems with my Philips DVD player since i bought it 2 yrs back. Only thing is that itz not DivX compatible
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 30-09-2007, 11:37 PM   #5 (permalink)
if interested .. then also take a look at cheap chinese players .. i bought one for my self .. with divx . xvid . usb .. vga out etc .. for 1.6 k .. works well ..and picture and sound is very good too ..
yogi_7272 is offline
Old 30-09-2007, 11:44 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
Check with Philips DVP 5965.. You can switch the resolution on the fly , plays most of the format. supports upto 1080i and also has a USB port. Downside is that its costs 5K .
Charan is online now
Old 01-10-2007, 10:33 AM   #7 (permalink)
ajayritik's Avatar
Dude I dont know the exact model number but I have seen LG DVD player which has all the features mentioned by you and it costs 8k.
ajayritik is offline
Old 01-10-2007, 10:58 AM   #8 (permalink)
Go for LG DN 192H DVD Player. It has HDMI and USB as well as DivX / XviD. Approx. price: 5k (I think its below 5k).
Check out the link below:
http://www.lgindia.com/Product/Produ...229&Proid=4197
Do not go for Philips. I have Philips DVP 3046 and after 6 months of purchasing as the warranty ended, the player stopped reading DivX discs. The service center took 1k for changing the laser head.
winzip is offline
Old 01-10-2007, 02:27 PM   #9 (permalink)
I’m considering mainly 2 models. One is Philips DVP 3166 for 3.3K. It has DivX (and Xvid also I think) and USB port.
2nd one is a Chinese/local model called Passion. Costs 1.5k only. Has all the features of the Philips model (including USB).
After hearing reports that Philips models also might go bad, I’m thinking of going for the Chinese model(as suggested by yogi_7272). Even if it goes bad after a year or so I don’t lose much.
But I have one question?. These players which support USB – do they support only flash drives, or are USB hard drives supported?. I was planning to purchase an external case for my old HDD and use it as a video jukebox kind of thing. Does anyone know if it’s possible?
Old 02-10-2007, 10:44 PM   #10 (permalink)
Update: Bought the "Passion" DVD player today for 1.5k. Fantastic stuff. It has everything I was looking for. Total VFM for 1.5K. It plays almost all formats that I tried
Best thing is..they have a 6 month warrany and they have a service center in town (just in case something goes bad). Even Philips gives 6 month warranty only
Old 02-10-2007, 11:51 PM   #11 (permalink)
good choice .. does it have usb + vga out + memory card reader ..?
Old 03-10-2007, 11:39 PM   #12 (permalink)
@yogi_7272, yes USB input is there, but no VGA or mem card reader.
Mem card reader is not a problem..I have a card reader.
The earlier model from the same company had a VGA out, but in the latest model it seems they have stopped it. Not sure why...maybe cost-cutting. In the manual as well as in the on screen menu, there are options for VGA out.
Anyways no plans of connecting to a monitor, so that doesnt bother me.
Old 03-10-2007, 11:52 PM   #13 (permalink)
dattebayo
anispace's Avatar
do u have any pics
anispace is offline
Old 05-10-2007, 01:11 PM   #14 (permalink)
Hey which audio and video formats does "Passion" DVD player support other than divx, xvid and mp3? Can i put mpeg and dat files to the root of the cd and does it play these files? Plz share all the supported formats. thanks.
casual_gamer is online now
Old 05-10-2007, 07:21 PM   #15 (permalink)
Reg audio formats I didnt try much...it plays mp3 anyway
I'm not using it as an mp3 player.
Video formats it played pretty much everything I threw at it.
Yeah it will play mpeg and dat if u copy it to root folder, or for that matter any folder. U can also browse to the required folder and select the file.
I have a movie collection containing a lot of avi files written in many different formats. Havent checked the codecs for each of these but DivX and Xvid is supported for sure. There were a few files which were not playing on my friend's Philips player, but they were playing fine on this one.
If I find any other formats supported, I'll let u know.
Old 06-10-2007, 09:31 AM   #16 (permalink)
^ok thanks. I am also curious about wma, aac and wmv formats.
Old 08-10-2007, 08:11 PM   #17 (permalink)
can u tell model no of that passion dvd player,in delhi where can i buy this?
http://www.passion-enterprises.com/
Last edited by sheelgupta31; 08-10-2007 at 08:16 PM. Reason: Automerged Doublepost
sheelgupta31 is offline
Old 08-10-2007, 09:07 PM   #18 (permalink)
Hi
can anyone tell me whats the maximum capacity of space HDD do these player supports ?
I heard players with USB support can read only from 2 GB drive ? They dont support 40 GB HDDs , Is that true ??
PraKs is offline
Old 09-10-2007, 11:45 PM   #19 (permalink)
Hey here is the aks
arunks's Avatar
what is the use of usb port in dvd player?..
is it a portable one.?
i mean is it with a screen or without screen?
what is its price with or without??
where can i buy it in my city i.e. patiala??
reply
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 13-10-2007, 09:13 PM   #20 (permalink)
it must be this one...
http://www.futurebazaar.com/b2c_futu...channel=mailer
2 day, I went 2 BigBazaar and saw it in real..but could not gt the demo as I was in hurry...
but at 1499 it is a steal...with 6 months warranty..
BTW there r no details abt DIVX versions supported in the manual.
gugulunaal,
what do u think of the quality? will it last?
ashnik is offline
Old 13-10-2007, 09:31 PM   #21 (permalink)
Ethan_Hunt's Avatar
Thats still a affordable price.When I initially got my DVP 5950 model it costed me around 4.5k & back then the DVP 5965 was around 7k or 8k.If you need a normal Divx compatible player then go in for the Philips DVP5950 one.It has a great Divx compatibility including Xvid & raw SVCD & VCD files.I have had it for 9 months now & no issues whatsoever.
V for Vendetta
Ethan_Hunt is offline
Old 13-10-2007, 09:46 PM   #22 (permalink)
left this forum longback
praka123's Avatar
mitashi dvd player with usb support.GIYF.
praka123 is offline
Old 13-10-2007, 11:20 PM   #23 (permalink)
gugulunaal,
Yes ashnik, the link you gave is correct..that is the same model I purchased. I dont have any snaps right now. But the pic in the link you gave is exactly the way it looks.
Build quality seems surprisingly good for a 1.5k player. Tray mechanism is quite good and sturdy, and overall it has a good fit and finish. Only prob I faced was that the video through the component video output had a slight ghosting effect. Not sure if it's a prob with the player or my TV. Never used the component input in my TV before. Normal composite video output was perfect. No probs.
Praks, I'm not sure whether it supports USB hard disks. It supports all the flash drives I tried. I was also able to connect my 4GB iPod mini (in hard dsk mode) thru USB and the player was able to play all the mp3 and video files on the HDD.
I dont think if it plays wma/asf. I had some wmv videos in one of my folders, but they were not even detected. But it plays DivX and xVid for sure. I've tried playing all kinds of divx and xvid files and all of them worked perfectly. Only problem I saw was that if the bitrate of the video was very high(very high quality videos), then there was a slight pixellation. Maybe the processor is not able to decode it fast enough. But no problem, the video plays well enough to be watched.
Overall I am extremely happy with the player
Old 21-10-2007, 01:36 AM   #24 (permalink)
Hey! can u tell me on which outlet did u see this player. I am also planning to buy this one.
rahulkharade is offline
Old 21-10-2007, 09:19 AM   #25 (permalink)
Got it from Big Bazaar (Trivandrum)
Old 21-10-2007, 09:29 AM   #26 (permalink)
The blackhole®
desai_amogh's Avatar
Thumbs down Re: Need suggestions to buy DVD player
my roommate got this model.. its Remote control sucks.. u have to literraly press 3 keys just to increase/decrease the volume .. & other features also have the same wierd interface ...
The remote control keys r very Hard & u at times endup clicking them 2-3 times to get them clicked ..
AMD Athlon II X4 635, MSI 880GMA - E45, Corsair value 2GB x 2, FSP Saga II 500W, APC UPS 600VA, Zebronix Bijli, Logitec Classic Mouse and keyboard
Lumix FZ35 Camera
Blog@ http://amoghdesai.com
+1 < click here to Rep me if I was helpful !
desai_amogh is offline
Old 21-10-2007, 09:16 PM   #27 (permalink)
Hey here is the aks
arunks's Avatar
reply
what is minimum cost of portable type dvd player and quality?
what is price of VIdeocon DTH DVD player??????????/
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 23-10-2007, 11:09 AM   #28 (permalink)
Finally bought same (passion) player from big bazar mumbai @ Rs. 1399.
& checked following formats through usb.
mp3,wma,mpg,mpeg,avi,divx......
all formats are playing through usb......
after then i made a data dvd of same formats.but it not is supported that dvd & not a single file played.all these formats can play through usb port only.
All dvds (actual original dvds of movies) are playing without any problem.
its a region free. & region code is given in manual with how to chenge the region information.
Old 24-10-2007, 10:36 PM   #29 (permalink)
You are talking abt the Philips model right ?
Hey I'm able to play data DVDs containing avi files (DivX and xVid). Are u sure u got the same model ?
In Big bazaar, they had an earlier model of Passion DVD player on display (test piece) with older firmware. That had some problems in recognizing some formats. Hope u havent bought the old model.
Old 09-11-2007, 12:23 AM   #30 (permalink)
bonny72's Avatar
Dear users , last week i went bigbazar, i saw PASSION DVD PLAYER only Rs.1399. i tested it with USB pen drive and DVD with all format video.
http://www.futurebazaar.com/b2c_futurebazaar/b2c/zmenuHandling.do?query_star=600108367&category=*&x =20&y=5&query=600108367*&min=0&max=0&min1=&max1=&r efsite=internalmailer_11&adunit=homepage&channel=m ailer
By look it is good, finishing it like branded dvd player, doesn't look like chines player, size is like Phillips 3166. it is only 1.8kg. front side four buttons open, play, ff, bw , back side it has all ports like standard DVD player has. it is true 5.1 DVD player, It has progressives Scan returns on it but i think when i played some low resolution video' i can clearly seen pixels, well in Rs.1399 it is best dvd player, i played lots of movies, even DVDs are working fine, and it has 6months warranty too,
List file format it supported.
DivX yes
Xvid yes
MP4 No (i tried two times, again i will try, if it will work i will let you know )
MPEG4 with AVI extension yes
MP3 yes
Jpeg yes
WMA yes
WMV no
MPG yes
DVD yes
USB port can play all above files , I tested with 1GB pen drive,
I also tested with USB HDD (2.5 seagate 80GB) it is not working with it.
i also tested with USB 3.5" seagate 160GB HDD , it is not working , it is just saying " waiting " but after 2 min , no positive results.
i used to download lots of movies from torrents sites, all English and Hindi, and i am very happy that all my movies are working in this player, i suggest everyone here to buy this player because it has all futures like Phillips player and it comes with 6 months warranty
bonny72 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/69401-need-suggestions-buy-dvd-player.html
Chip.in • View topic - Which DVD Player plays AVI files This thread Refback 02-09-2010 05:55 PM
suggestions for buying mp3 player?? Caesar Software Q&A 13 08-09-2007 06:48 PM
Can I watch all channels? <<media player or real player>> digidream Software Q&A 2 06-09-2005 04:42 PM
New 30 GIGS PDA + MP3 player + Video player Tuffleo Buying Advice 1 09-07-2005 03:51 PM
any suggestions????? mylifevp QnA (read only) 3 28-12-2004 08:15 AM
