Old 28-09-2007, 10:17 PM   #1 (permalink)
Cool G5's Avatar
Post Hack CD drive into Lab Scanner
HERE'S A TIP TO SAVE SOME $70,000 (Rs. 2807000)
Researchers at the Universidad Politécnica de Valencia, Spain needed a lab scanner, but didn't have the cash to pay for it, they didn't panic or started any hulabaloo about lack of funds. Instead, Angel Maqueira and his colleagues (must be inspired by Indian Scientist Great Late C.V.Raman) bought a bog-standard CD player &mdash and hacked it, saving themselves a potential $70,000 in the process. Here's how they did and how you can do it own your own Lab Scanner:
Fixing two additional light sensors to a normal CD or DVD drive can transform it into a highly accurate scanner for chemical or medical tests, Spanish researchers have shown. The team has developed a modified CD drive that detected tiny quantities of pesticide in samples placed on top of an ordinary compact disk.
Measuring light
Maquieira and colleagues soldered two extra light sensors inside a CD player, and used software to control the way the device "plays" a disk.
The first sensor identifies the sector of a disk containing a sample using black marks on the edge of the disk. The second analyses the sample itself, measuring the amount of laser light that is able to pass through the disk. The off-the-shelf disks used normally reflect around 30% of the laser beam onto the reading head, with the rest passing through.
In experiments, the researchers used their modified drive to detect traces of three different pesticides. A sample – half a millimetre across on a disk – was treated normally, using a set of reactions that produce an amount of dye or silver that is inversely proportional to the amount of pesticide in the sample.
The amount of laser light that passed through the disk to the second sensor indicated the levels of dye or silver. The modified drive was thus able to detect levels of pesticide as low as 0.02 micrograms per litre.
Although the hacked device lags behind the performance of specialised machines, it is accurate enough for many lab tasks.
High capacity
Other researchers have previously used the reading head from a CD drive to scan chemical samples. Using the whole drive is both faster and cheaper, Maquieira says.
Future disk drives may be even more useful, since next-generation systems like "Blu-ray and HD-DVD" use shorter wavelength lasers that are closer to those found inside laboratory machines.
Source:www.technonix.com
Cool G5 is offline
Old 28-09-2007, 10:24 PM   #2 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default Re: Hack CD drive into Lab Scanner
learn India learn.amazing use of brain power.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 29-09-2007, 01:01 PM   #3 (permalink)
Cool G5's Avatar
India has the potential but it's not used effectively.
Cool G5 is offline
Old 29-09-2007, 02:01 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
as a matter of fact, inventions like these mostly haf indian brainz behind them!
the problem here in india is corruption. imagine how much could middlemen, bureaucrats and politicians cud earn when making a purchase of $70,000 equipment??!!! this is the problem here!
infra_red_dude is offline
scanner and OCR kumarn_2004 Peripherals 4 05-05-2006 05:54 AM
Scanner ! ! ! ax3 Peripherals 2 30-09-2005 03:39 PM
Need to buy a new scanner under 5K sba Peripherals 1 25-09-2005 04:51 PM
