Old 28-09-2007, 07:19 PM   #1 (permalink)
mad1231moody's Avatar
Default Upgrade questions
Hey friends my friend wants to upgrade his PC.,,
His current specs are
P4 ,2.40 Ghz
256 MB ram
40 GB HDD
64 MB Onboard graphics
845 G Intel motherboard..
He wants to upgrade and I adviced him that b4 you do any upgradation upgrade your motherboard first. I hope I am right. So what the question is that he needs a motherboard which has DDR 2 and Sata support.
And the price limitation i upto Rs.3000. And he is not going to change the CPU. SO friends give some advice here
mad1231moody is offline
Old 28-09-2007, 07:22 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Upgrade questions
If you upgrade your motherboard, you'll need to upgrade your Processor (From socket 478 to 775 for the newer boards) AND get new DDR2 (DDR1 don't fit on DDR2 slots) RAM modules. That's definitely not in your budget. The motherboard itself would set you back by that amount.
QwertyManiac is offline
Old 28-09-2007, 07:30 PM   #3 (permalink)
Alright then the Old CPU will be of no use , if i get a new Mobo. Alright then i will ask my friend what is his budget again. And I think that he can spare some Rs.10000 for the total upgrade. So according to that he will be able to spare some Rs.6000 for the mobo+processor combined. Now what will be the best bet
Old 28-09-2007, 07:39 PM   #4 (permalink)
dOm1naTOr's Avatar
Asus M2NMX SE for 2.6k or MSI K9AGM2 for 2.4k nd AMD Athlon X2 4400+: 3.6k
Best deal for 6k. Decent onboard GFX + decent proccy.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 28-09-2007, 07:41 PM   #5 (permalink)
What is the onboard graphics on the mobo u mentioned and i dont get the term proccy
Old 28-09-2007, 07:47 PM   #6 (permalink)
dOm1naTOr's Avatar
proccy means processor.
M2NMX SE:
nvidia 410 chipset
onboard nvidia 6100 graphics with shader model 3.0
gr8 mother board
MSI K9AGM2:
ATI 690G based bomo
Onboard ATI X1250 graphics with shader model 2.0 [but performs much better than n6100 in all games].
g8r motherboard nd performs better than M2NMX.
G3: XPS M1530 |
FZ 16.
Old 28-09-2007, 07:52 PM   #7 (permalink)
Ok then I will opt for this then
MSI K9AGM2:
ATI R600 based bomo
what is the graphics memory in terms of size, i mean 64 MB or something like that
Old 28-09-2007, 07:55 PM   #8 (permalink)
dOm1naTOr's Avatar
X1250 can have max 1GB graphics memory + 256 MB xtra texture memory if u have enuf ram and u can also go as low as 64MB.
But the main drawback for MSI K9AGM2 is it has got only 2 mem slots.
Asus M2A VM is also 690G based mobo, but more features nd overclocking features. Itll cost u 3k, nd has 4 memory slots.
Both of them support max DDR2 800 Mhz. M2A supports max 8GB memory nd K9AGM2 supports max 4GB.
G3: XPS M1530 |
FZ 16.
Old 29-09-2007, 07:10 PM   #9 (permalink)
So there is no onboard graphics on the MSI mobo ???
I asked you that what will be the onboard graphics on MSI?? or there is nothing
Hey my question is that will I get any onboard memory for graphics or I will have to insert a graphic card
Last edited by mad1231moody; 29-09-2007 at 07:10 PM. Reason: Automerged Doublepost
Old 29-09-2007, 07:24 PM   #10 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Visit this thread u'll get ur answer as soon as Choto logs in.
Basic Guide to Purchase a new system
Harvik780 is offline
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
upgrade questions arnab_21111987 Hardware Q&A 12 08-05-2006 06:38 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
