Old 28-09-2007, 01:19 AM   #1 (permalink)
Red face Intel 945 GM problem or software ???
Hi...i recently bought a Lenovo N100 3000 series laptop. This is the configuration :
Intel Pentium dual core 1.73Ghz...
Mobile intel 945GM express chipset integrad graphics
2 GB Ram
120 GB SATA hard drive
and on board realtek soundcard
Windows Vista Home Premium
I tried to install a few games and play but its not workin.......i tried NFS most wanted but its too slow (the frame rate...) even thought the graphics is kept at low settings but still there is a lot of framing ! please let me know if i can do nething to solve this issue...i dont know if its a hardware issue....i installed the latest drivers and updated the BIOS but no use...apart from this the system works fine....
Another quest i had is ... wanted to know if i can change the on board chipset and add an pci-express graphics card to it... cause i cannot find any slot...but is ther any method to do so ?
And the last problem i hav is whenever i use yahoo or google chat the CPU usage shoots up nd the conversation looses its clarity and soon the call gets disconnected ....i donno why this happens ...
Please Help... !!!!
axiz_23 is offline
Old 28-09-2007, 04:07 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Intel 945 GM problem or software ???
you cant change a grxf card of a lappy for your self.. will voide the warrenty... and i am not even sure whether N100 had the support for ext grfx or not...
what ?? call gets DC mean ??
and try and re-install the GRFX drivers for the Vista !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Intel Chipset Software Installation Utility 6.3.0.1008 Sourabh CPU / Motherboards 3 21-04-2005 11:05 PM
Intel 865 GBF - problem ganesh_2218 CPU / Motherboards 2 30-12-2004 06:29 PM
