Old 27-09-2007, 08:17 PM   #1 (permalink)
kantiman's Avatar
Default DVD-RW Problem
Recently whenever I insert any disk into DVD drive the PC restarts instantly.
and also when I boot my PC for first time it doesn't boot. All the fans and HDD are working and all lights are ON including HDD activity. No beeps as well. After 1 minute I shut it down and again start it and Now it starts without any problems.
I have P4 1.8, intel 845GEBV2, Gforce Fx 5200, TV tuner card, Lan Card, 2 HDD and DVD RW. my SMPS is Zebronics 400W. my pc is around 3 1/2 years old.
kantiman is offline
Old 27-09-2007, 08:20 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: DVD-RW Problem
Firstly check for two things,
1. Check if the cables connecting the drives or other peripherals are loose and tighten them if they are.
2. Check if your system temperatures are normal. Also get your SMPS checked for fault!
QwertyManiac is offline
Old 27-09-2007, 09:22 PM   #3 (permalink)
kantiman's Avatar
The connections are good. may be the problem is due to SMPS.
kantiman is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
