Old 27-09-2007, 06:04 PM   #1 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
Default [SUGGEST] Components for a 10k pc (only mobo, processor, cabinet, hdd)
Well i hope the title says it all...
Pls suggest a Low end processor, mobo, cabinet and a hdd so that it totals to >=10k
this one i'll be building for a guy who works in a local shop.
i'll be donating my old monitor, combo drive and may be even a old 256 meg stick.
Please, reply asap with the current market price (if possible, in kolkata) adn any preferred shop (anywhere near chandni chowk).
aku is offline
Old 27-09-2007, 06:49 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: [SUGGEST] Components for a 10k pc (only mobo, processor, cabinet, hdd)
Processor: AMD Athlon 3200+ AM2 - Rs.2000
Motherboard: ASUS M2N8 - VMX AM2 (Nvidia Onboard Gfx) - Rs.3000
RAM: Transcend 512MB DDR2 - Rs.1200
HDD: Seagate 120GB SATA HDD - Rs.2100
Cabinet: Some Cheap Case+SMPS that goes for Rs.1200
Speakers: Some Cheap Ones (Frontech/Mercury) - Rs. 350
Keyboard: Mulimedia Keyboard - Rs 200
Mouse: Optical Mouse - Rs 400
Around 10450.. Not a Bad Config at all!
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 27-09-2007, 07:03 PM   #3 (permalink)
aku
Gonna make it BiG
aku's Avatar
woah... datx 1 heck of a config for a 10k pc.. tx a lot man...
btw can u also suggest a intel variant???
aku is offline
Old 27-09-2007, 07:15 PM   #4 (permalink)
For Intel :
Dual Core proccy e2140 - ~3000/-
Asus P5GCMX ~3000/-
rest as above.
For more details visit Choto's thread : http://www.thinkdigit.com/forum/showthread.php?t=66140
sashijoseph is offline
Old 27-09-2007, 08:44 PM   #5 (permalink)
foreign return(0)
comrade's Avatar
ATHLON AMD 64 - 3200+ AM2 2100
MSI K9AGM2 (onboard Ati Gfx better than nvidia) 2800
Transcend 1.0 GB-DDR2 667 MHZ - 1500
Seagate 160GB - SATA II 2400
Cabinet+400WSMPS 1200
Total: 10000
Athlon Dual core X2 4000+ will add an 800rs to the budget.
comrade is offline
Best Mobo,Processor, cabinet and RAM for under 12000 Nithin Reviews 13 09-10-2008 12:51 PM
Suggest Mobo+Processor+RAM for 15k soham Hardware Q&A 14 22-06-2007 01:29 PM
Pl suggest good processor + mobo HRISHIG Hardware Q&A 6 03-01-2007 07:59 PM
PLS SUGGEST THE BEST MOBO, PROCESSOR, RAM !!! Vishal Gupta Hardware Q&A 28 23-11-2005 02:18 PM
