Old 27-09-2007, 01:40 PM   #1 (permalink)
demoninside9's Avatar
Unhappy Pls help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!urgent
Motherboard = Asus P5PE-VM
CPU = Intel Pentium D 2.8 GHz
Memory = Kingston 512 MB PC3200 DDR
My problem is when i boot my computer theres an error appear....
"Intel CPU uCode Loading Error
Press F1 to Continue"
Ive tried to reinsert CPU and reset the CMOS but still no luck. Any idea how do i fix this?
there is no shortcut for SUCCESS
demoninside9 is offline
Old 27-09-2007, 01:51 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Pls help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!urgent
Most probably you'd need to update your BIOS. But wait for other solutions than this ..
QwertyManiac is offline
Old 27-09-2007, 02:51 PM   #3 (permalink)
assasin's Avatar
1st try to reset the bios by taking out the bios battery after disconnecting the pwr cord from smps.if u get same error after reseting bios then update ur BIOS.
assasin is offline
Old 27-09-2007, 02:56 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
the newer intel cpus shoudn't give a microcode error. try to find an option in bios to disable the microcode. otherwise hunt for a bios upgrade.
ps: plz use descriptive titles for all ur queries.
infra_red_dude is offline
**urgent Help** kudos_sam Software Q&A 3 04-03-2007 11:46 AM
Need urgent help sanju QnA (read only) 2 13-05-2006 04:05 PM
