| Forum |
#1 (permalink) |
foreign return(0)
i need to get my home a 29" TV with a max budget of 20K not beyond that. I have shortlisted these two 1. Samsung CS-29K44ML http://www.samsung.com/in/products/t...Specifications ![]() 2. Sony KV-SZ292M88 http://www.sony.co.in/product/kv-sz2...ite=hp_en_IN_i which one should i go for? any better option available? |
#2 (permalink) |
left this forum longback
LCD TV's do come under 20K?wait sometime when prices drops.rather carrying bulky CRT's.
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#4 (permalink) |
C# Be Sharp !
Dude u can buy Samsung's new slim CRT TV's .
i got a new one Last year n it's excellent , currently using it with Tata Sky n totally satisfied . These new CRT's although not as slim as LCD's are much much slimmer than conventional CRT's , just check em out at the store and you'll know the difference . http://www.samsung.com/in/products/t...ittv/index.asp
There are 10 types of people in the world: those who understand binary and those who do not. Last edited by Zeeshan Quireshi; 27-09-2007 at 12:07 PM. |
#6 (permalink) | |
foreign return(0)
#7 (permalink) |
Sup' dude, Sup'
Try: Philips 29PT2204/94R
http://www.consumer.philips.com/cons...P&compare=true Philips : 29PT6807/94 (with widescreen mode)
Introducing Windows Vista 2.0. Check it out at http://www.apple.com/macosx/leopard/index.html |
#8 (permalink) | |
I have to tell you all my story... I bought Videocon 29'' slim&trim tV on 17 of sept from vijay sales Mumbai...it got problem on very next day....like panel not working remot is not functioning...i got replacement....Now this TV also problematics works for 2-3 hrs then shut down automatically... Dont know wats the problem...Now vijay sales manager is ready to give me another replacement...But am confused now should i or shudent i.. I am thinking of Sony 21990/- Sp29 model...has woofer also... and Phillipse LCD 32'' 39990/- ..............but phillips made to think about their products also..but vijay sales manager told me that phillips inding is slowly shutting down there products and service will be problem in next few years... even i went to two thre another electonics shops where i didnt fond any phillpse TV with same reason.. So suggest something..isit truie... I am damn sure about sony but meanwhile samsunga dn phillps popping up in my mind?? wat to do avg period -5-7 years...am planning to buy Plasma after...? |
#10 (permalink) |
Sup' dude, Sup'
Philips lasts longer than Sony. Sony products are always on the delicate side. Video looks better on Philips and audio is better on Sony.
If I have Sony and Philips available, I will pick up Philips.
#11 (permalink) |
Go with Samsung, what I hear about it have no Problem with Service so far. But have rumors that it closing service center at Lemington road, so be clear where is service center for Samsung TV.
Why don't you allow HTML signature? |
#12 (permalink) | |
From the above models I would say pick Samsung DNIE model as it's has a good price-to-performance ratio.Sure the Sony one's are costly but their shelf life is extremely longer than any other brand.
"Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof. " V for Vendetta |
#14 (permalink) |
Sony TVs had been the best in terms of colour reproduction over the years due to their own picture tube technology called "Trinitron", compared to "shadow mask" and others for other brands. They were also much costlier. I think other well known brands have also come close in terms of picture quality.
Had been using Sony from 1982. Had used two sets for about 10 years each and then disposed. Using Samsung DNie for the last 3-4 years. (change not due to any particular reason. just happened to buy it)
V.Prem Kumar |
#15 (permalink) |
^Yep I have used it since 1981.I had one of those bulkier one's which had a wooden furnish to it.Had to let it go as the picture tube had neared it's end & was almost about to die out.Shifted to BPL about 4 years back.Now I am planning to shift to either a Samsung DNIE or back to Sony again depending on which one is more affordable.Probably the former as it's more for the budget consious consumers.I would loved to have gone in for a 34' CRT of Sony but I am not sure what the pricing is at this point.But I know I'll end up buying a 29' anyway so no use.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Which 32" LCD television? | vikramk | Hardware Q&A | 20 | 26-01-2009 10:48 PM |
| Recommend The Best CRT Television In Rs.25,000 Range. | pannaguma | Hardware Q&A | 16 | 30-07-2007 12:11 PM |
| Recommend best Mobo for C2D and Quad C2D in price range of 9K to 14K | ramu | Hardware Q&A | 3 | 17-06-2007 07:08 PM |
| Suggest a Good 29" Television in range of 15 - 25k | sbhas2k | QnA (read only) | 2 | 28-11-2006 09:04 PM |
| connect P.C. to Television | slugger | QnA (read only) | 7 | 02-09-2004 09:42 PM |
