| Forum |
#1 (permalink) |
Alter Bridge=GOD
Also please suggest a model.my eyes r on viewsonic 1912wm.
Apple Macbook Pro 17 |
#2 (permalink) |
M$™ Certified Spammer
go for widescreen trust me, it rocks and its mroe worth than a 4:3, go for the viewsonic ones they are great
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l |
#4 (permalink) |
No pain....No gain
Some games do need patch but most new games support widescreen resolutions.
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#5 (permalink) |
u can play most games without patch.
i cant play CS1.6/DOTA at native resolutions 1440*900(max. for 19 inch TFT widescreen).the machine completely freezes within 30 mins changing native resolution to 1024*768 solves the problem,though
DOTA is really addictive |
#6 (permalink) |
Deadman Walking
dude better go for widescreen its resolution is 1440/900 and gaming quality for viewing is extra ordinary,i suggest for viewsonic LCD
What looks to be nothing,finally that becomes everything... and what is everything suddenly that changes to nothing... Learn to live... & Live to learn... |
#7 (permalink) |
Alter Bridge=GOD
ok i'm going for widescreen.i went to local shop and the guy suggested samsung 940n instead of viewsonic 1912wm.is it better in picture quality?
#8 (permalink) |
No pain....No gain
Whichever you buy, just see if it has DVI input or not. AFAIK, both 940N and VG1912wm doesnot have DVI (digital) input.
#11 (permalink) |
Deadman Walking
how much can you bear dude dvi monitors are very cost viewsonic VP2130b
Ultra-Slim Bezel LCD costs 27000 i think for home purposes you can go for non DVI monitors and the cheaper DVI monitor by viewsonic is : ViewSonic VX2235WM 22" Widescreen LCD Monitor - 5ms, 700:1, WSXGA+ 1680x1050, DVI, Black·Silver costs 10,760 see this link http://www.tigerdirect.com/applicati...801&CatId=2775
What looks to be nothing,finally that becomes everything... and what is everything suddenly that changes to nothing... Learn to live... & Live to learn... Last edited by Batistabomb; 27-09-2007 at 04:20 PM. |
#12 (permalink) | |
VA1912w - no DVI VA1912wb - with DVI VG1921wm - no DVI VG1930wm - with DVI VA1912wb - ask specifically for this, check while purchasing that the box pack contains DVI cable
Therefore, enjoy as much as you can..... |
#16 (permalink) | |
No pain....No gain
#17 (permalink) |
Go for widescreen rather than normal screen they really looks better.
go for any Viewsonic model as per yr requirement.
Be like a postage stamp-stick to one thing until you get there. |
#18 (permalink) |
is a graphics card needed to use an LCD monitor. My current config is AMD 2.0 GHz 3200+ on a Gigabyte GA K8N51 GMF-9 mobo with 512 MB DDR400 RAM and onboard GPU nVidia GeForce 6100. M completely noob bout LCDs.Will this config run an LCD?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness Think of your 3 best friends. If they are OK, then it's YOU |
#19 (permalink) |
No pain....No gain
It will run fine.
#20 (permalink) |
Eh John. Thanx
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| AOC widescreen CRT??? Is it available? | bikdel | TVs / Monitors | 6 | 22-09-2007 12:03 AM |
| 22" Widescreen LCD @ 19,000! | godling | Hardware Q&A | 20 | 13-06-2007 04:48 PM |
| Widescreen Dillema | topgear | Hardware Q&A | 20 | 27-05-2007 05:30 AM |
| widescreen issue!! | speedyguy | QnA (read only) | 8 | 29-04-2007 01:23 PM |
| widescreen LCD | gksunil | Hardware Q&A | 3 | 23-04-2007 03:40 PM |
