Old 26-09-2007, 11:01 AM   #1 (permalink)
Default which pen drive to buy ?
please provide me current prices of different pen drives .
i am looking for a pen drive . for me 'brand' is not an issue . but I want to but a pendrive which is of good quality . I mean which is reliable in storing data .
Also , looks is NOT an issue .
yes price is an issue for me . I want as cheap as possibe .
Space is also an issue . I am looking for as much sape as possible .
dearkumar is offline
Old 26-09-2007, 11:10 AM   #2 (permalink)
tuxfan's Avatar
Default Re: which pen drive to buy ?
Transcend. Don't buy V30, look for some high speed model like JF 168. Capacity will depend on your budget.
tuxfan is offline
Old 26-09-2007, 11:17 AM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
Kingston 2GB pendrives are available for less than Rs900 now.
I heard it is available for Rs 770, but not sure about it.
4Gb pendrives will cost you Rs1500.
As for the make, Kingston is better than Transcend. Now you can locate the computer peripheral dealers around you and ask for the rates are decide acc. to your preference.
www.twitter.com/alsiladka
alsiladka is offline
Old 26-09-2007, 11:20 AM   #4 (permalink)
Cool G5's Avatar
If your budget is very shoestring get i-ball cutility pen drive.It is a little delicate,so you have to handle it carefully.
If you can spare around Rs.900~1000,you can easily get a 2GB Kingston Data traveler.It's performance is good.
Whatever you go for atleast look for a 1 GB model,don't go below that.
Cool G5 is offline
Old 26-09-2007, 11:33 AM   #5 (permalink)
ok I am thinking of buying 2gb kingston .
well what are the maximum capacities for a pen drive ? do they come with 8gb / 12 gb also ?
I am looking for 4 gb ( more likely ) or at least 2 gb .
Old 26-09-2007, 11:39 AM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
yes 8gb drives are available but considering the lower capacity ones the cost per GB is high for these.
except the transcend V30 series all other models are pretty fine. kingston data traveller is also a good option. another choice is the sandisk cruzer series. they are all priced in the same range. wud cruzer you haf a retracting usb connector and hence a cap for the connector is eliminated.
infra_red_dude is offline
Old 26-09-2007, 02:59 PM   #7 (permalink)
Thumbs up Re: which pen drive to buy ?
Dude,
go for TOSHIBA pendrives !!
awesum looks, good value for money and u can get u3 for the price of a regular one!!
innovative softwares loaded!! i jus bought it recently on sugestion of a friend!! believe me its gr8 !!
mumbaiite123 is offline
Old 26-09-2007, 04:22 PM   #8 (permalink)
Cool G5's Avatar
Kingston Data Traveler:
2 GB:Rs.800~900
4 GB:Rs.1800~1900.
Cool G5 is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
mounting sata drive & pen drive vish786 Open Source 9 11-05-2007 07:14 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
