Old 25-09-2007, 10:13 PM   #1 (permalink)
Default intel D845 board audio problem.....
i recently formatted my computer and loaded winxp sp2 into it..... i tried installin th audio driver given in th motherboard disk and t didn't work.... so i downloaded th latest driver from th intel site but th system restarts during th installation process....... plz help
deepakprabhakaran is offline
Old 25-09-2007, 11:19 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: intel D845 board audio problem.....
Please mention the full motherboard make and model number... Do you have High Defination audio ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 26-09-2007, 12:44 AM   #3 (permalink)
slugger's Avatar
well it appears that d member has infact mentioned d mobo chipset
so assumin dat hes got original intel mobo, it means dat he does not have HD audio
u mite wan2 install Realtek's AC'97 Audio Codecs
but ur comp re-startin in d middle of install seems strange
slugger is offline
Old 26-09-2007, 12:46 AM   #4 (permalink)
Rebooting
I faced this type of problem with D101 boards while it didnt have KB888111 installed , but if its really 845 then thats out of question...
rebooting
ChotoCheeta.com
Old 26-09-2007, 01:13 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Few motherboards support audio only on XP with SP. But intel 845 dont have any such issue.I have intel 845 motherboard at my home....and working fine for last 4 years.
Was there any problem with ur sound card ..before U reinstalled your XP.
ravi_9793 is offline
Old 26-09-2007, 07:59 PM   #6 (permalink)
the make of th board is intel.... th prob is it jus restarts.... first it says a files are missing though they are present... i have manually locate th files... then th installation continues and suddenly restarts in th middle......
Is Intel Board is the best? vasulic CPU / Motherboards 12 28-09-2005 06:55 PM
915 Mother Board .. Intel Or ......? mukundpathak CPU / Motherboards 12 24-07-2005 03:35 PM
Audio Problem on Intel 845GVSR Motherboard need urgent help! ramireddy_y CPU / Motherboards 4 12-07-2005 05:13 PM
Intel board help Tech&ME CPU / Motherboards 3 11-04-2005 04:26 PM
