Old 25-09-2007, 01:10 PM   #1 (permalink)
666
solomon_paulraj's Avatar
Exclamation TV Tuner Card Problem!
ok here is the problem.. one of my comp. conf is.
945 GCL MB
1GB RAM
GeFor 6600
i have bought Leadtek winfast 2000 xp global..
but how do i connect the audio input to the tv tuner.. my Motherboard has 5.1 channel o/p at rear..(which im using) the front panel audio is also connected..
guys plz help.
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 29-09-2007, 09:36 AM   #2 (permalink)
666
Default Re: TV Tuner Card Problem!
what is this man 25 views and no solution for the problem.. where are the pro's gone..
aree yaar help me no..
Old 29-09-2007, 10:06 AM   #3 (permalink)
99.9% Idle
axxo's Avatar
do u want to connect audio out of tuner card to linein of soundcard..if is it so..just cascade the connection with a cable most probably line in socket will be in blue color...
axxo is offline
Old 29-09-2007, 10:10 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Have you got a small wire (about 1 ft.)..having both end that can be inserted in audio jack.
If yes...than inserset one end of wire in ur TV tuner card..and another in mic port of sound card.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 29-09-2007, 11:43 AM   #5 (permalink)
666
the three ports (pink, blue and green) are being used by 5.1 speakers. so i have no option to use line-in function or mic-in function. also i dont have aux connector on the motherboard.
the motherboard has front panel mic-in and audio-out.
any option??
Old 29-09-2007, 11:45 AM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
any option??
read the manual book....and also help section of TV tuner card installed on ur system. your solution must be written there.
TechTin.com
Old 29-09-2007, 12:00 PM   #7 (permalink)
AJJU
azzu's Avatar
solomon sir ur lecturer
but ur attitude is very different
I love and Live to Design
azzu is offline
Old 29-09-2007, 12:11 PM   #8 (permalink)
666
that doesn't solve the problem.
Old 30-09-2007, 01:06 PM   #9 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
any option??
your onboard audio solution must have atleast a 4 male pin internal " cd-in " or called as " cd volume " audio connector on mobo if u dont have aux-in
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 30-09-2007, 01:43 PM   #10 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
945 GCL MB
1GB RAM
GeFor 6600
guys plz help.
I dont know in the mean time whether your problem got solved or not. Once I have faced same problem, I solved the problem this way. I have cut down one end of the audio cable supplied with the TV tuner card (external TV tuner Card) and that end directely connected by soldering to the amplifier of the speaker and the other end conatinig the jack connected in the audio out post of TV Tuner Card. Original Audio cable of the speaker as usual connected to the PC But there is a problem. when u switch on TV tuner directly without switching the PC the sound quality is ok, if the pc is running and u wish to watch TV without shut down the PC the sound quality is poor, ie volume slow down also a hising sound appear.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
TV tuner card problem george101 Hardware Q&A 2 06-01-2007 12:45 PM
tv tuner card remote problem kk_k2k Hardware Q&A 2 09-11-2006 06:28 PM
problem with tv tuner card ????????? nvidiasingh2006mb Hardware Q&A 1 13-02-2006 04:26 PM
Problem with tv tuner card indian QnA (read only) 1 11-10-2005 04:59 PM
