Old 24-09-2007, 07:53 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default Problem with USB pen drive
Today while I trying to setup Win Xp to a system, during that process setup shows me partition of the hard drive, where it also shows the free space of USB Pen drive which was erroneously connected and I forgot the same. I think the free space of usb pen drive is of hard drive and I deleted that drive. After the mistake I realised that I have actuallay deleted the usb pen drive's partition.
Now when I insert the the pen drive the system recognised it as a removable Drive in MY Computer Folder. When I double click it to open the drive it shows msg as "Please insert a disk in drive M:"
2. If I right clik in My computer>manage>Disk management is shows Disk 1(Removabale m: no media). If I right click it shows the option a) change drive letter and path b)eject c)properties d) help.
Please Note :
USB config
Apacer USB 2.0 Flash Drive 1 GB( www.apacer.com)
(Handy steno AH320 Compressor)
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 24-09-2007, 08:06 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Problem with USB pen drive
Pretty Weird, Atleast there should be a 'Unallocated Space'.
Did you try using Symantec Partition Magic?
Did Apacer give any softwares with the Pen Drive?
http://india.apacer.com/in/support/downloads.asp -> Go There, Select your Product and download the LFormat/Repair Tool
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 24-09-2007, 09:46 PM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Thanks subbzzz vbmenu_register("postmenu_614091", true);
I have downloaded the repair utility from ://india.apacer.com/in/support/downloads.asp . But the exact product type did not work. I have downloaded 3 utility from their site. Finally One of the repair Utility passed. Now My Pen drive is working.
Dvd Drive Problem 56561 Hardware Q&A 3 27-07-2007 12:09 AM
Pen Drive Problem Him007 QnA (read only) 12 27-06-2006 05:50 PM
CD drive problem m.parthiban QnA (read only) 7 26-09-2005 10:07 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
