Old 23-09-2007, 05:38 PM   #1 (permalink)
vavinashraju's Avatar
Unhappy New sata liteon drive not working....please help
hi bought a new sata liteon lh20a1s dvd writer ......i connected the sata data cable to the first sata port and the power cable also ...my problem is that after starting the computer it correctly opening and closing which means i think power cable is correctly connected
but when i try to read to some cd or dvd it is not reading any thing...i dont know where i m missing some thing but it is a new one please help...
"The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila."
vavinashraju is offline
Old 23-09-2007, 09:21 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: New sata liteon drive not working....please help
Try a firmware update.Which company CD/DVDs did you use.??If it was some cheap DVD,then it can be a cause of problem.
Life is as complicated as you say it is.
shady_inc is offline
Old 23-09-2007, 09:25 PM   #3 (permalink)
assasin's Avatar
ur writer may cuz prob u hav set SATA to AHCI mode in BIOS.
assasin is offline
Old 24-09-2007, 05:21 PM   #4 (permalink)
Arrow Re: New sata liteon drive not working....please help
i searched in the bios but there is no option for setting sata to AHC1....please if u could tell me in a more detailed way what i have to do it would be nice
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
New Liteon DVD-RW not working gaurav4gurls Hardware Q&A 2 01-04-2006 03:04 AM
liteon drive problem hsnayvid QnA (read only) 5 08-08-2005 10:11 PM
