| Forum |
#1 (permalink) |
my pc is working after connecting this home made converter. all i wud like to know is whether its safe to use a such a converter which draws power from the default 4-pin ATX connector of the psu and provides pwr to the 8-pin EATX connector on the mobo. |
#2 (permalink) |
Try me
its surely safe , if the connector you made is nicelt soldered and insulated.. just check the joints and they should not be loose.. else everything is fine..
Forum rules: http://www.thinkdigit.com/forum/announcement.php?f=3 Blog at : http://thecomputernext.com/blog |
#3 (permalink) | |
V.Prem Kumar |
#4 (permalink) |
its very easy to make one.all u will need is a bad psu(cuz will need to cut out the 8 pin block from the 24 pin mobo connector) or u can buy urself a 20-pin to 24-pin converter for 20 bucks(i' prefer the 2nd one cuz u can connect the 4-pin ATX connector to the 20-pin female jack).
all the yellow connectors in the 4-pin ATX connector r +12V and black r for COM/GRND.in the 8-pin connector all the top 4-pins r for +12v and the bottom 4-pin r for GRND..if u cant understand this 1st connect ur 4-pin ATX connector to the 8-pin EATX connector.see to which 2 holes correspond to +12v.the 2 holes adjacent to these +12v holes will also be +12v and the rest 4 for GRND.now map ur wires accordingly. Last edited by assasin; 24-09-2007 at 11:13 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to get a 6-pin connection from 8-pin connector of PSU | Red_Baron | Hardware Q&A | 16 | 26-07-2007 06:24 PM |
| How to connect to DVI connector | dhawald | QnA (read only) | 1 | 26-09-2006 01:30 AM |
| Where can i find this Connector..? | Dipen01 | QnA (read only) | 3 | 26-08-2006 10:12 PM |
| IDE Connector Issue.. | dreams | Hardware Q&A | 4 | 28-01-2006 03:25 PM |
| USB Connector In P3 | sainit | Peripherals | 3 | 09-07-2005 02:20 PM |
