| Forum |
#1 (permalink) |
I want to know which cable i should use so that the hard disk work. I am using usb cable that came with the case but it is too small to use . Only i can use hard disk if i work on laptop as i can keep the harddisk on the table ,but for desktop i cant keep the harddisk on table. It is difficult to use hard disk with desktop computer as i have to keep hard disk on floor to connect to usb port. I try to use 2.0 cable 2 meters lenght but the hard disk dont work with that extention cable. Vendor said u cannot get 2 meters cable to work on the external hard disk.
AMIT AGARWAL |
#2 (permalink) |
yup USB cables have a limit of length upto which they can detect and transfer d data from a USB device
go and ask for a USB cable, u may try 2 join 2 USB cable to increase its length but 2 metre is too long for d device to be dtected |
#4 (permalink) | |
Also does he is using it on usb case containing hard disk I tried to use 2.0 USB Cable 2 meters long on Thumb drive and it worked but it is not working on harddisk. So how much maximum meters extention cable can i use for Hard disk any idea.
AMIT AGARWAL |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 4GB transcend V30 | chicha | Hardware Q&A | 4 | 07-09-2007 12:47 PM |
| Transcend Storejet 2.5" 40GB :-( | loveyaseen | QnA (read only) | 3 | 05-04-2005 04:58 PM |
| how to get cable tv in a cable internet connection | bishnu_rath | Internet & WWW | 13 | 12-03-2005 12:52 PM |
