Old 22-09-2007, 10:02 PM   #1 (permalink)
Default frustrated ! system not booting
My AMD system stopped working a month back . i tried doing everything but it wouldnot boot . so i assumed the problekm is with the motherboard and sent to asus service centre and checked it was found to be alright and the processor was faulty so i sent the processor to amd for replacement but warrenty was voided because the processor had burn marks . except the processor nothing seem to be damaged everything was working fine when i tried with other processor . my motherboard and ram where lying for a month without the processor . today i bought a 939 3500+ processor and tried booting the system but it wouldnot boot . all i got was the keyboard lights ( num lock , scroll , lock and caps lock ) blinking continously . what could be the problem ?
my system configuration
asus a8n-vm motherboard
amd athlon64 3500+ processor ( 939 socket )
512 ddr ram
Dont die of ignorance .
digitizen is offline
Old 22-09-2007, 10:20 PM   #2 (permalink)
"The Gentleman"
vish786's Avatar
Default Re: frustrated ! system not booting
what type of sounds do u get... as soon as u start ur system.... i mean how many beeps. ??
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 22-09-2007, 10:23 PM   #3 (permalink)
well i dont have a cabinet speaker connected . all i can tell u is all the lights in the keyboard blink continously .
Old 22-09-2007, 10:28 PM   #4 (permalink)
"The Gentleman"
vish786's Avatar
with the info what u hav provided no one can help in d forum.... u first connect ur mobo speaker to it... and connect every peripheral one by one to check ur problems its the simple way if u really now how to go about tryin to trouble shoot it.
- Dijkstra
vish786 is offline
Old 23-09-2007, 12:45 PM   #5 (permalink)
Web developer
narangz's Avatar
Also check if your motherboard BIOS supports the new processor frequency. If not upgrade your Motherboard BIOS. You can get the latest BIOS files from ASUS's website
narangz is offline
Old 23-09-2007, 05:22 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
check the connection properly.All connection should be proper connected and at right plan.
Than comes compatible issue:check your motherboard manula for supported processor.
Also tight-up all the cable/connection inside the cabinet.
ravi_9793 is offline
system booting problem sanftpup Hardware Q&A 4 22-08-2007 11:20 AM
System Display goes off while booting rajivnedungadi Hardware Q&A 3 24-11-2006 01:58 AM
How To Configure My System For Dual Or Triple Booting ????? clmlbx Software Q&A 3 14-09-2006 09:19 PM
frustrated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! kunwar QnA (read only) 5 10-05-2005 04:37 PM
Urgent...Please help.....winxp system not booting Darthvader Software Q&A 4 08-02-2005 09:20 PM
