whenever i try 2 login,the keyboard n mousepad ceases to work or keeps hanging if THE BATTERY TO THE LAPTOP IS CONNECTED.
but as soon as i remove the battery,it starts up fine.
i hav a 256MB RAM...and i bought an additional 512MB but owing to these problem,i am not sure if i should upgrade the RAM.
The laptop is an intel centrino 2005 make from acer...how do i know if the motherboard supports the extra RAM?
Please hellp...
bt hw am i supposed to know the make of my mobo???
u see,for laptop they dont exactly give the manuals...and its has juzz 1 extra slot.also the problem exists with 256MB of RAM
Maybe the battery is defective in some way.
As for the extra ram...take out the existing one and compare the pin count and position of slot(s) etc.If identical push in the new one.
You may post a link of this thread here : 100% repair of Laptop & Desktop Motherboard
Mr Sandip Golani is the laptop expert out here and may give a proper solution.
