Old 22-09-2007, 07:01 AM   #1 (permalink)
vavinashraju's Avatar
Question which dvd writer to buy sony or liteon
there are many dvd drives available in the market which one should i go for ....i m planning to go for either sony or lite-on..which drive should i go for please help and i m going to college now i will check this page when i return....please mention exact name like last time i asked the dealer for sony dru 80a and he gave me dru 50a model....
is it better to buy from some local dealer or should i got to the rashi peripherals or to the lite on main dealer.....where would i get more warantty...because the local dealers give only one year warranty
"The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila."
vavinashraju is offline
Old 22-09-2007, 08:03 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: which dvd writer to buy sony or liteon
Both are good... but now days there are tons of Duplicacy with Sony... so u would pay more for sony but u may get a Duplicate product I would say Lite-on then
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 22-09-2007, 09:44 PM   #3 (permalink)
Smile Re: which dvd writer to buy sony or liteon
thanx for the suggestion......
Old 22-09-2007, 10:54 PM   #4 (permalink)
als2's Avatar
sony no doubt but careful about dulicate one
als2 is offline
Old 22-09-2007, 10:57 PM   #5 (permalink)
left this forum longback
praka123's Avatar
why dont ya get sata dvd writer?(sony)
praka123 is offline
Old 23-09-2007, 01:35 AM   #6 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
say yes to liteon dude.I mean see all the reviews and recommendations by tech. magazines.Liteon is cheaper(relatively) and performs better.Choice is yours to make buddy.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 25-09-2007, 12:31 PM   #7 (permalink)
Techzilla!
rahul30's Avatar
see if u compare between the two both have performed well..but sony generally comes under the OEM pack (in kolkata atleast)....so it really boils around to ur priority
amd x4 635 , Gigabyte 880 GM-UD2H, 2gb ddr3 corsair, 500 gb w.d caviar green, benq G2220hd , CM 310, CM 500w Extereme Plus , Tritton AX 720 Pro
rahul30 is offline
Old 25-09-2007, 12:35 PM   #8 (permalink)
Cool G5's Avatar
I suggest you take Liteon LH-20A1P.Cheap & Best.
Cool G5 is offline
Old 25-09-2007, 01:51 PM   #9 (permalink)
bajaj151's Avatar
Using Liteon LH-20A1P form past 3 months......its gud....
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 25-09-2007, 02:09 PM   #10 (permalink)
Techie By Heart
mavihs's Avatar
my vote goes for Lite-ON
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 28-09-2007, 12:56 PM   #11 (permalink)
go for liteon, but check if proper service is available at ur place
rohitm_001 is offline
Old 29-09-2007, 01:29 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
sony ....... always the best ......... been using it 4 past 10 months ....... no problems ........
... W H O T ...
ax3 is offline
Old 30-09-2007, 11:24 AM   #13 (permalink)
99.9% Idle
axxo's Avatar
both are bad in my opinion....market is flooded with too many duplicate sony products..i myself own a liteon which losts its cd read/write abilities after a year although it still read/write dvds quite ok...so my suggestion is stick to standard products like LG.
axxo is offline
Old 30-09-2007, 11:37 AM   #14 (permalink)
Samsung.
SunnyChahal is offline
Old 30-09-2007, 11:39 AM   #15 (permalink)
AJJU
azzu's Avatar
lite-on
I love and Live to Design
azzu is offline
Old 01-10-2007, 09:33 PM   #16 (permalink)
GeekyBoy's Avatar
I've heard people saying that Lite-on drives fail to read some digit/chip DVDs ?
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 01-10-2007, 10:14 PM   #17 (permalink)
Liteon makes drives for sony.
dosent matter which u buy
W i d e S c r e e N is offline
Old 01-10-2007, 10:18 PM   #18 (permalink)
praka123's Avatar
...and plextor,pioneer drives are they available in India?
praka123 is offline
Old 01-10-2007, 10:26 PM   #19 (permalink)
I think pioneer are available.One of my friend has one of it.
Old 01-10-2007, 10:27 PM   #20 (permalink)
praka123's Avatar
^then it will be way better than these all drives listed.may be costly too,na?
praka123 is offline
Old 01-10-2007, 10:29 PM   #21 (permalink)
Dunno about the prices but I dont think anything can be better than LITEON.LITEON dvd writers simply rock.even LG ones are good but not as good as liteon
Old 01-10-2007, 10:51 PM   #22 (permalink)
praka123's Avatar
LG DVD-RW failed for me twice.not recommended.
praka123 is offline
Liteon DVD Writer Problem khandu Hardware Q&A 3 27-01-2007 10:51 PM
Burn failures with Liteon SHM-165H6S writer stiffler Hardware Q&A 2 03-01-2007 08:40 AM
Liteon DVD Writer model number ambandla QnA (read only) 4 02-01-2007 10:23 PM
LiteOn or Sony parimal QnA (read only) 12 17-03-2005 12:08 AM
