Old 21-09-2007, 07:41 PM   #1 (permalink)
Default Upgrade Rd RAM to 4GB
I have Intel 850 M/B with (64x4) 256 MB RD RAM
Please advise me how I am Upgrade RAM of my PC ?
avidasioc is offline
Old 21-09-2007, 07:58 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Upgrade Rd RAM to 4GB
1 GB x 4? I don't think that motherboard will support 4 GB though! It supports just a max of 2 GB like mostl old motherboards do. So that'll be:
2 x 1 GB or 4 x 512 MB
QwertyManiac is offline
Old 21-09-2007, 08:23 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
850, RDRAM? expensive combo man!!! it won't support 4GB. 2GB is the max. plus getting 2GB ram (in whatever stick config) wud be hard and expensive for you. it'd be better to sell this mobo and buy another socket478 mobo (searching a bit can get u one) and going in for 2GB or 4GB DDR2 ram. that will actually work out to be cheaper than thinking of buying 4GB RDRAM.
btw, 4GB RDRAM is only supported in intel 820 and intel 860 chipsets.
infra_red_dude is offline
Old 21-09-2007, 10:47 PM   #4 (permalink)
RDRam?
4GB?
If at all you are able to get it it will be at very exorbitant cost and for that amount you will be able to build a modern high end system!
V.Prem Kumar
janitha is offline
Upgrade woo-hoos to Upgrade blues. Help! mightyboosh Hardware Q&A 1 27-11-2006 12:14 AM
Ram Upgrade vineetrocks2005 QnA (read only) 4 25-08-2006 11:40 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Best Upgrade Possible d Hardware Q&A 7 14-12-2005 10:24 PM
