Old 21-09-2007, 10:04 AM   #1 (permalink)
Default Speaker Related Querys
Hi all,
can any one sugest me the 2.1 speaker set. My budget is 1500Rs.
My PC Configuration is
Intel Dual Core 3.2
Intel D965RY Motherboard
1GB Ram Kingston(667MHz)
Thanks.
Ashutosh Malik is offline
Old 21-09-2007, 02:35 PM   #2 (permalink)
slugger's Avatar
Default Re: Speaker Related Querys
for aorund dat budget u will get Creative Inspire 2.1
slugger is offline
Old 21-09-2007, 02:38 PM   #3 (permalink)
Kiran.dks's Avatar
Artis also has good models in that range delivering 1000W PMPO. I personally have one from past 2 years. Working pretty well. I love it's ability to deliver undistorted Bass even at high volumes.
Kiran Kumar R
Kiran.dks is offline
Old 21-09-2007, 06:17 PM   #4 (permalink)
786
RajU
786's Avatar
For that price, will you get Creative Inspire 2.1 as said by slugger, good sound quality/clarity, bass.
I can assure u that you will love it
nO pAST, nO fUTURE, Just Now
config: *2007 YZF-R1*
E6750 @3.2GHz; asus p5k-vm; 2gb JETRAM @800MHz(4-4-4-12); 250gb seagate; ZEB 500w; xfx 9600gt
786 is offline
Old 21-09-2007, 08:36 PM   #5 (permalink)
coolsunny's Avatar
go for altec lansing 2.1 speaker..
coolsunny is offline
Old 21-09-2007, 08:52 PM   #6 (permalink)
creative will be good 4 u as other companies don't have comparable ones in that range.
ashnik is offline
Old 21-09-2007, 10:41 PM   #7 (permalink)
@coolsunny
Altec Lancing ATP3 will cost about 2.5K. But maybe there are lower cost models of AL.
@Kiran_tech_mania
PMPO is absolutely meaningless. Even >50W RMS will do justice.
V.Prem Kumar
janitha is offline
Old 21-09-2007, 10:43 PM   #8 (permalink)
dOm1naTOr's Avatar
Altec Lansing 121i has better sound quality than Inspire 2.1 nd SBS370. Its about 1.15k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 22-09-2007, 11:00 AM   #9 (permalink)
Thanks u all 4 suggestions.my first choice is Altech 2.1. But Money play a big rool.
Old 22-09-2007, 11:51 AM   #10 (permalink)
pushkaraj's Avatar
check this out -> http://www.creative.com/products/pro...&product=15970
The Creative M2600 costs about 1900/- in lamington road,mumbai.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 22-09-2007, 12:07 PM   #11 (permalink)
Kiran.dks's Avatar
Originally Posted by janitha
@coolsunny
@Kiran_tech_mania
Yep! You are right. I am aware of it. I have developed my own 2.1 channel sound system with 80W RMS for each channel too in my college days using IC Chips. It also included a 10 Band Graphic equalizier and a DTS BT Board.
Kiran Kumar R
Old 22-09-2007, 05:03 PM   #12 (permalink)
Same with me. Had also published circuits in 'Electronics Hobbyist' (now defunct) and EFY during college days. But once employed, never had time other than for reading about newer things.
V.Prem Kumar
janitha is offline
4.1 Speaker spp_itim Hardware Q&A 11 01-03-2007 02:55 PM
which speaker to buy??? saikibryan Hardware Q&A 13 02-02-2007 10:37 PM
best speaker? Rs > 10k 56561 Hardware Q&A 5 14-06-2006 12:35 AM
Speaker with parimal_xp2003 Audio 3 20-06-2005 08:18 PM
