Linksys
WRT54G is one of the best and it has very good range, So it suits your home well!
Well, Its advertised to have a Range of 100mts, So the Connection Quality maybe degraded if you are using it from another floor.
Nope! WiFi is nothing but Wireless LAN, it has a speed of 54mbps avg. I don't think it'll affect your 256k/2mpbs Broadband.
(And Yes, I Hope you are using ADSL, Its nearly impossible to share LAN Cable Internet using it. like Sify, it needs a Software 'Dialer' for that!)
