i have Asus M2V NPM motherboard with amd athlon 64 3600+..i recently installed windows xp sp1 .when i try to install audio drivers (soundmax ADI1968A Audio driver )... it says
plz help..........
Errrm.....The pic's resolution is way too small buddy.It's hard to read what the error message is & also I tried zooming in but still can barely read the text.Please attach a bigger image & if possible try to use SP2 if possible & check if that helps.
V for Vendetta
oh i just enabled thumbnail image for space saving sorry...it says audio driver files do not support your hardware ....i had broken my CD of sp3 so had installed this..now ab ye problem
by the way my 500th post in digit forum ..yipeeeeeeeee
yar koi to reply karo...lagta hai dobara se win2000 sp4 install karna padega
Reason: Automerged Doublepost
First thing:
1)Install service pack 2.Most motherboard driver need XP SP2
2) Try installing by double click the seetup file.Dont use default installation at autorun.
3) If still you can install..than download the latest driver for ur motherboard from the MOB manufacturer's website.
