Old 20-09-2007, 06:45 AM   #1 (permalink)
Default Possible Motherboard failure?
When i turn on the computer all i see are verticle lines of different colors in parallel across the entire screen. The power supply and monitor work fine and the video card isnt too old... any thoughts?
Thanks!
Nexenn is offline
Old 20-09-2007, 08:18 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Possible Motherboard failure?
Try degaussing you moniter. If this doest not help ..than ur graphice card is having some problem. If this is a graphics card probelm..than All you need is to get a new cheap graphics card(very low end).
Also check the graphics setting in the control panel.
ravi_9793 is offline
Old 20-09-2007, 08:27 AM   #3 (permalink)
Most probably it's a gpu issue,but try reseating the ram as well.....I've seen many strange problems with (loose) ram sticks.
sashijoseph is offline
Old 20-09-2007, 08:28 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
@Nexenn
Post ur full system config along with running OS...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-09-2007, 10:16 PM   #5 (permalink)
its been a while since ive felt familiar with some of the hardware lingo
The PC im talking about is running windows XP, i have 1 gb ram, 3.0ghz hyperthreading P4, and a relatively new 128mb nvidea card because the old one craped out. The screen works fine, im actually using it right now on another PC so i know the problem lies in the case somewhere. I have recently cleaned the dust out with a can of air and put a different hard drive in with the exact same result when i hit the on button. In addition, i made sure everything is attached properly to the motherboard. The screen instantly shows verticle lines without showing any text whatsoever.
PS What is seeding the ram mean?
Thanks guys!
Nexenn is offline
Old 24-09-2007, 10:21 PM   #6 (permalink)
High without substance...
chicha's Avatar
there could only be one reason, a faulty graphic card. Take the card out and then try. mostly its the card, Motherboards usually do not go bad easly, provided that there was high voltage to it.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 24-09-2007, 10:27 PM   #7 (permalink)
awesome, i'll run to bestbuy or walmart and buy a new card for it... if it doesnt work i'll just return it lol im suprised it would be that though, it would mean the computer has shot out 2 cards in like a 9 month period
Nexenn is offline
CRC Failure prajantika Software Q&A 2 23-05-2006 12:33 AM
S.M.A.R.T Failure q3_abhi QnA (read only) 2 02-06-2005 11:35 AM
FDC Failure shyam911 QnA (read only) 2 25-03-2005 08:22 PM
Sound Failure sachin_kothari QnA (read only) 1 22-02-2005 10:58 PM
motherboard failure!!!!!!!!!!!!!!!!! tukaibatman CPU / Motherboards 4 26-12-2004 12:33 PM
